Old 07-15-2000
skweeks skweeks is offline
Senior Member
skweeks has a reputation beyond reputeskweeks has a reputation beyond reputeskweeks has a reputation beyond reputeskweeks has a reputation beyond reputeskweeks has a reputation beyond reputeskweeks has a reputation beyond reputeskweeks has a reputation beyond reputeskweeks has a reputation beyond reputeskweeks has a reputation beyond reputeskweeks has a reputation beyond reputeskweeks has a reputation beyond repute
Wink
would anything get hurt if i plugged a rackmount guitar preamp into my normal guitar amp and used that preamp as well? would it blow the preamp in my head or what?
Old 07-15-2000
virtual.ray virtual.ray is offline
Force of Nature
virtual.ray is on a distinguished road
Wink
It probably won't hurt your amp,but unless you keep the output of your preamp pretty low,it probably won;t sound very good,either,'cause the preamp outputs a line level signal whereas your amp wants to see the tiny signal most guitars put out.Cheers!
Old 07-17-2000
Senior Member
Wink
i don't think i can bypass the preamp on my amp.. what if i just turned the preamp control to 0 and used the "main" control for volume
Old 07-17-2000
Force of Nature
Exclamation
I think there's a little confusion here.When I said "keep the output of your preamp low" I was referring to the rackmount unit's final output volume,which I assumed you wanted to plug into the normal guitar input on your amp.Am I right so far?
Old 07-18-2000
Senior Member
Wink
yeah, that's clear
Old 07-18-2000
Gear_Junky's Avatar
Gear_Junky Gear_Junky is offline
The SCXD Defender
Gear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond reputeGear_Junky has a reputation beyond repute
Wink
If you have an FX loop try plugging into the "in" jack - that might be "after" the preamp.
Old 07-18-2000
Force of Nature
Wink
That's the next thing I was going to suggest;higher probability of level matching w/this scenario.
