Old 04-11-2004
notbradsohner notbradsohner is offline
Compression Addict
notbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond repute
easier bass trap plans
does anyone have some CAD or other drawings to better explain ethan winers bass traps. I have the article, but i cannot understand the construction process. mabye like views from above and the side. thanks
when the dust all settles and all of us have gone our life ways, the only thing anybody will care about in those recordings is the content. The songs and how they are performed. - SouthSIDE Glen
Old 04-11-2004
Ethan Winer's Avatar
Ethan Winer Ethan Winer is offline
Why 2K?
Ethan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond repute
Lightbulb Re: easier bass trap plans
Brad,
> i cannot understand the construction process <
At the very end of the article is a link to view the plans as a large GIF file which you can then print. Here's a direct link to that file:
www.ethanwiner.com/BTPlans.gif
Note that these are all top views, looking down into the traps. You also have to cap off the top and bottom to make them air tight. These plans show the top being open.
--Ethan
The acoustic treatment experts
Old 04-11-2004
Compression Addict
wow, never saw that. sorry ethan!
Old 04-11-2004
GoneinUS GoneinUS is offline
Junior Member
GoneinUS is on a distinguished road
Ethan, would these bass trap work in a portable type fashion? Say creating the bass traps not attached to the wall, but another piece of plywood that is movable?
Old 04-11-2004
geet73's Avatar
geet73 geet73 is offline
OMG!
geet73 has a reputation beyond reputegeet73 has a reputation beyond reputegeet73 has a reputation beyond reputegeet73 has a reputation beyond reputegeet73 has a reputation beyond reputegeet73 has a reputation beyond reputegeet73 has a reputation beyond reputegeet73 has a reputation beyond reputegeet73 has a reputation beyond reputegeet73 has a reputation beyond reputegeet73 has a reputation beyond repute
Couldn't I just have a piece of 703 across a corner as a bass trap?
Or does it have to be boxed in?
Old 04-12-2004
Why 2K?
Lightbulb
Gone:
> would these bass trap work in a portable type fashion? <
Yes, you can build a back panel. But it must be rigid and massive, and air tight, and you must place the completed trap right up against the wall.
Geet:
> Couldn't I just have a piece of 703 across a corner as a bass trap? <
Sure, that works fine, especially in smaller rooms. See the Acoustics FAQ, second in the list on my Articles page:
www.ethanwiner.com/articles.html
--Ethan
Old 04-12-2004
HangDawg's Avatar
HangDawg HangDawg is offline
bUnGhOlIo
HangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond repute
I've eliminated all vertical 90Ø corners with 3" thick 2' wide rigid fiberglas floor to ceiling. It has worked wonders.
http://www.garagerecording.com/images/lava22.gif
SELECT W.People
FROM tbl_world W
WHERE W.Clue = TRUE
NO RECORDS RETURNED
Old 04-12-2004
geet73's Avatar
OMG!
I thought it was OK.. I just wasn't sure. I see "airtight" everywhere. Heh.
Does iT have to be floor to ceiling? I have some outlets in the way.
EDIT: HangDawg, where you at in PA? I'm playing a show in Lewisberg next week. It might be Lewistown, they're both kinda close.
Old 04-12-2004
HangDawg's Avatar
bUnGhOlIo
I'm in williamsport. That's about 20 miles north of Lewisburgh. Not sure about Lewistown.
Floor to ceiling is best I imagine. You could just cut a hole for the outlets.
SELECT W.People
FROM tbl_world W
WHERE W.Clue = TRUE
NO RECORDS RETURNED
Old 04-12-2004
cellardweller's Avatar
cellardweller cellardweller is offline
Subterranean Sovereign
cellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond repute
Originally posted by Ethan Winer
Gone:
How massive? Is 3/4 in. plywood massive enough?
--Ethan
How small??? Is it just relative in smaller rooms? Do you mean that ANYTHING is an improvement in smaller rooms? Will smaller rooms still greatly benefit from membrane traps as opposed to 703 across the corner?
Old 04-13-2004
Why 2K?
Lightbulb
CD,
> How massive? Is 3/4 in. plywood massive enough? <
Yes, especially if you screw and glue cross bars across the back to keep it from flexing.
> Do you mean that ANYTHING is an improvement in smaller rooms? Will smaller rooms still greatly benefit from membrane traps as opposed to 703 across the corner? <
Yes, anything is an improvement in any room.
Panel traps work well in any size room. But they're a lot of effort to build, and they exceed fiberglass traps mainly when placed flat on a wall. A small room has less wall space, and proportionately more corners, than a large room, so fiberglass across the corners makes more sense there.
--Ethan
  #12
Old 09-10-2004
kfrugia kfrugia is offline
Newbie
kfrugia is on a distinguished road
What do you recommend?
I have a garage that is roughly 18x23.5x9.5. I mostly record drums and I would like to build some of the traps mentioned in the Ethan Winer article.
The garage layout is shown in the following picture:
http://ad.cavortingimps.com/~kirby/garage.jpg
The left wall is 2 layers of 5/8" sheetrock with insulation.
The right wall is 1 layer of 3/8" sheetrock with insulation.
The bottom wall is mainly a 16x8' garage door, insulated
The top wall is a 12x8' garage door, insulated and a human-sized door.
My question: how many of the bass traps do you think would be sufficient? I can't afford to put them around the entire garage. Any other helpful tips? I am a beginner.
Thanks,
Kirby
  #13
Old 09-11-2004
Why 2K?
Lightbulb
Kirby,
> how many of the bass traps do you think would be sufficient? <
I already answered you in my Acoustics forum at www.musicplayer.com.
--Ethan
  #14
Old 09-11-2004
BigHighLonesome BigHighLonesome is offline
Junior Member
BigHighLonesome is on a distinguished road
Hello Ethan.
I am new to the forums and I am building a studio in my basement (14*35*9).
Is this a good size room in your opinion and how many bass traps should I have? I will be checking out your materials for sure. I am quite new to studio construction but by all means not new to music and sound wave theory.
BHL.
When confused listen to the music play.
  #15
Old 09-12-2004
Why 2K?
Lightbulb
BH,
> Is this a good size room in your opinion and how many bass traps should I have? <
A lot of this is covered in my Acoustics FAQ linked above. Also see my article in the current (September) issue of EQ magazine. It's exactly what you need.
--Ethan
  #16
Old 09-12-2004
Junior Member
Thank you Ethan.
I am new here, I will do a bit more reading before I start buggin you for further information. Thats an amazing article btw. This is really going to get my ideas goin'. Perfect starting point and beyond.
Its almost worth putting a link in your sig to that with a quote "Read this first before asking!"
LOL Thanks again.
