Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 04-05-2004
TXABE TXABE is offline
Newbie
TXABE is on a distinguished road
Midi Connection Questionz
Hello every1, my question is, for connecting 2 midi controllers (keyboard & drum machine) simultaneously what do u all recommend? I have a laptop with win xp and about 512 ram. The only soundcard ive seen with 2x2 connection is "frontier design dakota 24-bit soundcard) & USB connectors like "Midiman Midisport 2x2". I also want 2 be able to record the external keyboard sounds and external drum machine sounds probably using Acid Pro 4.
Old 04-06-2004
Krakit's Avatar
Krakit Krakit is offline
Rzzzzz!
Krakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond repute
Re: Midi Connection Questionz
Sounds like a merger might do the trick.
2 ins, 1 out.
As long as your drums are on channel 10 and your keyboard is on channel 1 (or any other two different channels, but those should be the default), you'll be fine.
Unless you try to send too much event data at one time, but I'm going to guess that won't happen.
As for recording the sounds, you'll need to either use standard audio output from the devices into the audio input of your card.
Some more modern toys have S/PDIF or TOSlink optical digial outs and ins. That would be the way to go if your gear has that capability.
Carl
“The modern conservative is engaged in one of man's oldest exercises in moral philosophy;
that is, the search for a superior moral justification for selfishness.”
-John Kenneth Galbraith
