Old 04-02-2004
tubesrawsom's Avatar
tubesrawsom tubesrawsom is offline
BE HAPPY!
tubesrawsom will become famous soon enough
Question compresser
is a compresser better as an inline or a loop?
Iron What?
Old 04-02-2004
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Inline or insert loop is pretty much the same thing....
You normally wouldn't use a compressor via aux sends/returns though.
Old 04-05-2004
BE HAPPY!
thanx
Iron What?
Old 04-08-2004
Adzzz Adzzz is offline
Rock Out wiv ya Sock Out
Adzzz is on a distinguished road
really? why not?
i've never thought of doing that, but does it somehow degrade the audio signal, or what's the deal?
Old 04-08-2004
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
The normal patch is to send the entire signall through. Auxes normally get used to do a blend. A less typical app. is to mix the compressed version with the original. An aux could be used for that.
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Old 04-10-2004
BE HAPPY!
if i use aux wont i have to use an extra channel for the compression
Iron What?
Old 04-10-2004
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
If you insert the compressor you don't use an extra channel - It's in the channel you insert it into.
John Scrip - www.massivemastering.com
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 04-10-2004
Sen's Avatar
Sen Sen is offline
InFaze.Studio
Sen is on a distinguished road
He/she said: if I use aux, not if I insert....
yeah if you want to bring the compressed signal back to the board and blend it with the uncompressed..you will naturally need a separate channel
good luck
Sen
www.infazestudio.com
Old 04-11-2004
MISTERQCUE's Avatar
MISTERQCUE MISTERQCUE is offline
Not Just Anutha Brutha
MISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond reputeMISTERQCUE has a reputation beyond repute
I think you misunderstood what mixsit is stating about auxes.
Auxes are basically used for signal "effect" processors such as 'Verb's, Chorusing, Delay's etc. to the desired signal while your INSERTS are used to connect signal "dynamic" processors such as comps and eq'lizrs.
In particular, please note that compressors are not designed or used as a "effect" device (unless you're using a 3630 ) per se, but to control a signal's dynamics where needed such as peak control,compression, response, leveling, etc. along with gating, de-essing and normalizing functions.
Your question on comp application as either "inline" or "loop"
indicates you need to take the time out to learn and understand the basics of compression and use of same. Believe me, I'm not trying to belittle you or come off as some-1 who's holier than thou, it's just that years back, I ran my 1st ever comp thru the auxes thinking thats the way it was w/o giving myself the benefit of understanding the unit's purpose. At least you have inquired about it's connection, now take it a step further and learn ias much as you can about it!
Peace
Q.rM
Old 04-11-2004
VTgreen81's Avatar
VTgreen81 VTgreen81 is offline
Dedicated Member
VTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond reputeVTgreen81 has a reputation beyond repute
this may be helpful
http://www.ethanwiner.com/compressors.html
not with routing, but use of compression
Old 04-11-2004
Anything you send to/through the aux (generally) gets sent to and blended into the main mix along with the source track. You could decide to route an aux-return to a new track.
I may have clouded the issue with the compressor-on-an-aux comment.(?) You can blend a track's compression with the source just as you would add in a bit of delay, for a slightly different effect, but that has nothing to do with whether it gets returned to a new track.
To open that up a bit more, look at it as being several ways to get to the same place. The track gets split off; from an aux, or it could be a new copy of the track -same as the term 'mult' (for multiple just in case... )
It runs through what ever effect you hang on it, and back to the mix> an aux master return direct injected at the main mix, or to a new track or channel, recorded as a new track -or not.
It comes down to whichever fits.
