Old 03-28-2004
artCROSS artCROSS is offline
Senior Member
artCROSS is on a distinguished road
sonar and duo
I can't get the audio driver bit depth setting in SONAR 3 to be 24bit. I'm using an M Audio Duo and I know it is capable of 24bit/96khz, but it will only let me record in 16/41. I have downloaded the new drives from M Audio's site, but still can't get it to work. Any help would be greatly appreciated.
Old 03-28-2004
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
Do you have another sound card in your computer? Disable it under Options > Audio > Drivers.
Then set the M-Audio as your playback and recording master under Options > Audio > General. On the same page, set your Audio Driver and File Bit Depth to 24.
Run the Wave Profiler and I think afterwards you'll need to exit and reenter Sonar.
Old 03-28-2004
Senior Member
yeah, i tried disabling my onboard soundcard, but to no avail. I also ran the profiler, but still having the same problem. If it helps, the onboard audio says crystal wdm audio, but it is not selected.
Old 04-01-2004
sellthekids's Avatar
sellthekids sellthekids is offline
Senior Member
sellthekids is on a distinguished road
I use the quattro which is basically the same. You change the bit rate in the m audio controll panel. You might have to go to the m audio websit e and download the latest driver. The higher the bit rate the less inputs you have .
