Go Back   Home Recording > User Forums by Brand > Roland, Boss, VS Series Forum
Reply    Audiofanzine Roland boss Roland boss News Roland boss Medias Roland boss Tests Roland boss Articles Roland boss User Reviews Roland boss Classifieds Ads
Old 03-27-2004
D. Parting D. Parting is offline
Newbie
D. Parting is on a distinguished road
Arrow Normalizing
Alright, often times I record a track, and instead of being in the sweet spot, the signal's a bit too weak. When I try to mix, this particular track, jacked all the way up, is too low. Even when the other track volumes have been reduced to near 0.
How do I give this 'weak track' a boost? I only need to fix this one track.
I believe the term is normalizing.
Old 03-29-2004
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Normalizing doesn't really help. You need to use compression and/or limiting.
Old 03-29-2004
Newbie
Hm. I tried a compressor at a ratio of the lowest, which I believe was either 1:1 or 1.5:1 and had the effect level 12 db. It messed with the signal and sounded 'processed' and lost some quality.
Is there a better way, or is this the price I have to pay for bad input levels?
Old 04-01-2004
Foo-bu Foo-bu is offline
Senior Member
Foo-bu is a jewel in the roughFoo-bu is a jewel in the roughFoo-bu is a jewel in the rough
i have the same problem and have been trying to figure it out for a while. i find that my channel levels sound great but when it comes to doing the masters, i find the mix to be too quiet. even when the max peak is at -2db
Old 04-02-2004
Audio Bum
Using compressors can be tricky. You might try doing a search as there have a been a lot of tutorials. It also makes a big difference what compressor you use. The software ones built into DAW's usually aren't that great.
Old 04-08-2004
Phosphene's Avatar
Phosphene Phosphene is offline
Horse Diaper
Phosphene has a reputation beyond reputePhosphene has a reputation beyond reputePhosphene has a reputation beyond reputePhosphene has a reputation beyond reputePhosphene has a reputation beyond reputePhosphene has a reputation beyond reputePhosphene has a reputation beyond reputePhosphene has a reputation beyond reputePhosphene has a reputation beyond reputePhosphene has a reputation beyond reputePhosphene has a reputation beyond repute
quick and easy fix is just to goto the Track mixer screen and add 6 db with the attenuator in the top left corner. (that's all you can add, but it helps)
Strange noises, Bag not filling as often, Damaged cord, Indicator lights acting up......Phosphene's Songs from the Skull of Pavlov
Old 04-08-2004
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Re: Normalizing
Originally posted by D. Parting
... Even when the other track volumes have been reduced to near 0.
I'm not a Roland user, but might 'near zero' be where they're suposed to be?
Wayne
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
