Old 03-19-2004
Jaguar Jaguar is offline
Newbie
Jaguar is on a distinguished road
Lightbulb outboard compression vs. dsp card compression
would a decent outboard compressor improve the sound
of my VOCALS, if im allready using the compressors of uad and powercore ???
especially the uad has great great compressors, would
a nice outboard compressor like...let me say...FMR RNC add
somethin to my sound ???
thanxs in advance !
Old 03-19-2004
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
First off, I am a HUGE fan of the UAD plugs, and use them often and always.
That being said, sometimes there just isn't a substitute for analog hardware.
If I were still tracking and mixing a lot, I would be a firm believer in "compressors & lots of 'em."
John Scrip - www.massivemastering.com
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 03-19-2004
Middleman's Avatar
Middleman Middleman is offline
Professional Amateur
Middleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond repute
Depends on the type of music you are recording. The RNC will not add color near as pleasing as the UAD or Powercore. However in most software apps, plugins are applied after the track is already written to the hard drive. The RNC, when set up as a limiter, would control transients during the recording process, something the cards may not be able to do.
If you use the RNC for the compression color, you will be disappointed up against the coloration of something like the 1176 or LA2A that comes on the cards. This is not its forte.
Protools will allow you to route into a bus first and then back into a track for real-time compression however, there is some latency with this technique. In this case you can actually use the UAD/Powercore in real time. The need for an external compressor is less in this instance.
Sonar, no way, all plugs are after the write to hard drive and if you do not have a limiter or slight compression prior to the soundcard, your written file may have some hotspots. In fact I use the RNC to limit externally and then when I need color I use the 1176, LA2A or Fairchild from a UAD on the recorded tracks.
Another low cost external limiter/compressor is the DBX 160x which can be had for the same price as the RNC. I find it smoother on vocals with the over easy switch turned on than the RNC.
On the other end of things the RNC has a nice clarity with the super nice button selected, slightly grainy, but sometimes just the right thing.
Old 03-20-2004
Rev E Rev E is offline
Force of Nature
Rev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond repute
I second what Middleman said. Using the RNC as a way to simply control dynamic range on input into the soundcard is the best use of the RNC. For that there's no substitute. This will give you the better result when used in combination with the UAD plugs me thinks.
