Radium 61 and USB problem.
I'm probably missing something very simple but...
I have a Radium 61 Keyboard/controller hooked up to my USB port. I'm using Sonar 3 and have enabled the Radium as an input device within Sonar, but when I try to play a soft synth or record notes to a midi track, I get nothing. I also have it configured to control the faders in Sonar, which it does fine. But no MIDI note input. I should add that when I plug a MIDI cable in to the MIDI out port of the Radium and then in to the MIDI in port on my SB Live card, I do get MIDI notes in to Sonar. Also, if I keep the Radium plugged into the USB port (for power purposes) and use the MIDI out port of the Radium into the SB live MIDI in, I also get MIDI notes into Sonar. I also have an Audiophile 2496 card, but I have it's midi ports connected to a Johnson J-Station and would like to keep it that way. I want to be able input MIDI notes to the USB port and remove that SB Live card all together. Any advice would be appreciated.
