Old 03-18-2004
Bert0529 Bert0529 is offline
Newbie
Bert0529 is on a distinguished road
SONAR 3's relationship with my PC.
I've been drooling over Sonar 3 Producer for a couple weeks now and am ready to purchase a new computer to acommodate it. In the past people have reccommended using your DAW PC for that purpose alone. I don't have the luxury of doing that. I have to buy one big Frankenstein of a desktop that can do it all. I'm planning on a 73G SCSI drive and the latest, speediest P4 with a full gig of RAM. (I'm still debating the sound card. If you have a suggestion please let me know.) Will this scenario work for me? I'd rather have my dreams dashed now than after I open a bunch of boxes. Also how many 24-bit tracks will I be able to record and playback simultaneously in Sonar? Is there anything else I should consider in terms of computer specs?
Thank you!
Old 03-18-2004
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
Re: SONAR 3's relationship with my PC.
Sonar allows for an unlimted number of tracks. The limitation is the amount of horsepower your computer system has. The number of realtime effects you run, your sound card and its drivers, and your latency settings will also impact overall performance.
Using your computer for other purposes shouldn't be a problem, but you might want to consider a dual boot system. This will allow you to only load the bare necessities when you plan on working on your DAW.
Lastly, you probably want to consider a second hard drive just to keep your audio on. It is one of the better performance enhancements available to you.
Old 03-18-2004
Qwerty's Avatar
Qwerty Qwerty is offline
1K Silver Member
Qwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond repute
I just upgraded a P4 1.8 w/- 1G of RAM up to a P4 3.0 w/- 1G of PC3200 RAM, (800MHz FSB).
I set up a dual boot system, one with everything games etc., and one for audio. One installed as a ACPI MultiProcessor PC the other as a Standard PC
I cannot pick a difference in operation between both configurations. There is no speed difference or configuration dramas - it just works equally well in either boot mode.
So said, I would still recommend the dual boot system for ease of configuration.
I haven't found the upper track limit yet.
My old configuration used to crap out loading two instances of iZotope's Trash at 5msec latency.
I can now run eight instances of Trash and hit about 73% CPU utilisation.
Enjoy it!
Q.
<insert something witty here>
Old 03-19-2004
Newbie
What is the best type of hard drive for a DAW? What is the attribute that makes one drive better than another for this application?
Thanks!
Old 03-19-2004
dachay2tnr's Avatar
One Hit Wonder
Thanks!
The two attributes I would concentrate on are speed (rpm) and quietness. You want one that is at least 7200 RPM.
Old 03-19-2004
Newbie
Thank you.
Is there a particular spec I can check to determine the quietness of the drive? I've been looking at 15K RPM SCSI's. Is there anything better? or is that going overboard? I'd love to reduce cost, but not in a way that will be a detriment to the recordings.
Old 03-19-2004
Qwerty's Avatar
1K Silver Member
I think a 15k SCSI drive is overkill.
A 7,200 ATA-100 in a modern PC will easily do the job for you.
Q.
Old 03-19-2004
acidrock's Avatar
acidrock acidrock is offline
Better than great!
acidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond repute
That's a lot of trash!
Old 03-21-2004
Darryl79 Darryl79 is offline
Newbie
Darryl79 is on a distinguished road
Raptor Hard drives from Newegg
Thank you.
You can also go for a newer 36.7 gig Western Digital drive. It's called the "Raptor" and spins at 10k. Right now it is $117.00. That will save you quite a few bucks from the SCSI configuration.
(36.7) Newegg Link - http://www.newegg.com/app/viewProduc...144-200&depa=0
There is also a 73 Gig version for $217.00. Also spinning at 10k
(73 Gig) Newegg Link - http://www.newegg.com/app/viewProduc...144-160&depa=0
Both those drives also come with a 5 yr MGFR warranty. That is very important.
Old 03-22-2004
Newbie
Thanks very much, everybody!
