vs880 problems.. newb here :(
Heeello. I'm using a Roland vs880 and all i wanna do is apply external effects to a track that has been recorded. So i've got the aux sends going to the effect, and the effect coming back in to inputs 1 and 2. So i'm sure its plugged in correctly? The annoying part is i'm reading the step by step way to do it from the manual.. but its not working.
After i change all the settings in "track mix", and "input mix" do i then put it back into "input -- > track" mode to listen back? because thats what i did and the effect wasn't applied. I also tried to listen back in the other modes as well but... no dice. It is a microverb unit and all the knobs are turned up. THanks |
Go to the VSPlanet:
http://www.vsplanet.com/cgi-bin/ubb/ultimatebb.cgi Ask your question in the 880 forum...or perhaps to a search first. There's lots of good info and knowledgable people there. Good luck! Wish |
Thanks wish, i'll be sure to check it out!
