Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 03-12-2004
calidus calidus is offline
Junior Member
calidus is on a distinguished road
samples batch conversion?
Hi there
I bought a sample cd in AKAI format, bought it cuz I it was very cheap, 70% off regular price.
I can work with the samples within Kontakt BUT....
1 My cd-rw drive (it's the only cd-unit I have on my pc and it has F letter) doesn't recognize the cd as a cd-rom so...how the heck should I be able to burn a backup copy?
2 Halion ( I have 1.1) doesn't recognize the format either....only Giga and Soundfont show up in the import window.
I guess AKAI>wav is the format that would fit best. How do I do that?
Thank you
Old 03-12-2004
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
You should be able to burn a copy as a data disc. If they are instruments with samples you can't just convert them easily that I am aware of.
Old 03-12-2004
Junior Member
see what I found
Actually I must admit that I had prior knowledge of a couple of conversion tools, though at >130$, so I hoped someone could provide a cheaper solution or workaround. The apps I'm talking about:
http://www.cdxtract.com/home.php
http://www.chickensys.com/translator/index.html
Then I found this one, I don't get how SF2 relates to wav, but I guess this has to be the kind of tool I was looking for
http://www.nexoft.net/products/sampl...SampliConv.htm
any thought? Should I go for it?
Old 03-13-2004
Audio Bum
Those look pretty cool. SF2 is a soundfont file. The Soundblaster cards will read Soundfonts. I'm not sure who else will.
You are dealing with two different entities when you convert samples. The actual sound file and the instrument definition. You want to be careful you don't lose the instrument setup unless you are just using loops or want to rebuild the instrument from scratch.
Old 03-15-2004
zuke zuke is offline
Newbie
zuke is on a distinguished road
Try Awave Studio, best one out there.
However, you could read off the original cd rom if you know how to switch certain devices off in the os so that it doesn not use default recognition and simply shows the data it actually was recorded as.
But you could use Awave Studi and that will load entire banks and convert to any format you want.
http://www.samplecraze.com/images/links/samplecrazelogo.gif
