Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 03-10-2004
rib rib is offline
Newbie
rib is on a distinguished road
pwer amps or powered speakers?
I am in a situation where, i have non-powered speakers and just need a mixer, but i don't want a powered mixer, should i use the speakers for something else and buy new powered speakers along with the mixer...or get a power amp with the mixer, i am leaning towards the power amp desicion, good choice?
Old 03-10-2004
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
I tend to lean towards power amps - I'm not a big fan of most crossovers in powered monitors, and with a power amp and a speaker selector switch you can run your A set and your B set (or even a set in another room) from the same amp.
I'm a big fan of Halfer amps if that helps...
John Scrip - www.massivemastering.com
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 03-10-2004
tdukex tdukex is offline
Man of the Muse
tdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond reputetdukex has a reputation beyond repute
If you like your speakers and feel you can mix well with them buy a power amp. If they aren't very good to begin with, you can either buy a power amp and a better set of speakers or get some powered speakers. I would audition as many as I could and worry more about which ones I like most and could afford rather than if they are powered or not.
Of course, having a power amp in the studio can come in real handy.
Either way, the mixer should be a seperate issue, and powered mixers aren't favored for recording.
