| View Poll Results: Did this thread help you? | |||
| Very Much!! Thanks!! |
0 | 0% |
| Somewhat... |
1 | 50.00% |
| Nope. |
1 | 50.00% |
| Hell no, fucked my whole mix up!! |
0 | 0% |
| Voters: 2. You may not vote on this poll | |||
Thread Tools | Display Modes |
This is meant to be a guideline to help get you started. This is NOT meant to be a cookie cutter solution to everything. Remember, if it sounds good, it IS good.
------------------------ Kick Drum - Boost at 80hz, cut around 350-400hz, (removes "cardboard" sound) and beater smack is around 2-4 k. Snare Drum - Fatness at 240 hz, crispness at 5k Hats/Cymbals - Gong sound at 200hz, shimmer/air between 8-12k. Toms - Boom between 60 and 200 hz, scoop out 100hz to 4 khz, attack at 5k. Bass - Boost between 80 and 150 hz. To make a passive bass sound active, scoop around 350hz. Boost 800hz for clarity or punch and the slappin' poppin' thing is around 2.5k. Electric Guitar - Rolloff at 80hz, cut at 800 hz to remove "cheap" sound, and edge is around 2.5k Acoustic Guitar - Bottom at 120hz, body at 240hz, clarity at 2.5 to 5k Piano/Organ - Just like acoustic guitar except piano might need a little boost around 10k. Vocals - Scoop at 240hz. if muddy, boost at 4k for presence and anywhere above 8k to brighten (sibilance is between 8 and 10 k). ------------------- Good Luck, hope it helps ;] Smoove
TriState Entertainment Last edited by Smoove03; 03-09-2004 at 08:05.. |
I remember reading this on another site, a few years ago. I probably have it printed out, in my files. Definatly, some good info, a good starting point.
