Old 03-07-2004
Adam_46&2 Adam_46&2 is offline
Newbie
Adam_46&2 is on a distinguished road
Hard Disk to Computer Recording
I have a Roland VS-840...the quality is VERY good...but I want to record the audio into computer software.
Just wondering how extensive I need to go on the sound card. Will the Audigy 2 depreciate the quality?
Any other suggestions on cards in the 100-200 dollar range?
Old 03-07-2004
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
I'm pretty sure that box has a coaxial S/PDIF, no?
If so, make sure you get a card with a coaxial S/PDIF I/O and your pretty much set. Two tracks at a time.
(If it has an ADAT optical (Not TOSlink or Optical S/PDIF) you can transfer 8 tracks to an audio interface with ADAT I/O.)
KEEP IN MIND that S/PDIF cables are different than regular RCA cables.
Also, if you're doing this in real-time, you should probably put a quick "CLICK" at the head of every track that you're going to transfer - You can use the click as a visual aid when lining the tracks up on the DAW.
John Scrip - www.massivemastering.com
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
