Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 03-07-2004
GothGirl GothGirl is offline
Newbie
GothGirl is on a distinguished road
Question need to get my midi tracks in Cubase SX into audio
I need help to get my midi tracks that I recorded in Cubase SX into audio so I can make a wave file from the tracks...do you know of a good way to do that?
Belita Adair
Old 03-07-2004
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
I'm not a MIDI type, and I'm not exactly sure how Cubase handles that aspect (not in the manual?).
If nothing else, get the TapeIT VST plugin and put it on the insert. It'll receord a WAV file in real time from whatever is going to your soundcard through that insert. You'll have to line the tracks up later... Maybe a quick 16th at the head of every track so you have something visual to lock on with...
John Scrip - www.massivemastering.com
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 03-07-2004
Hi_D_Ho_Man's Avatar
Hi_D_Ho_Man Hi_D_Ho_Man is offline
Tha' So & So ,So & So
Hi_D_Ho_Man has a reputation beyond reputeHi_D_Ho_Man has a reputation beyond reputeHi_D_Ho_Man has a reputation beyond reputeHi_D_Ho_Man has a reputation beyond reputeHi_D_Ho_Man has a reputation beyond reputeHi_D_Ho_Man has a reputation beyond reputeHi_D_Ho_Man has a reputation beyond reputeHi_D_Ho_Man has a reputation beyond reputeHi_D_Ho_Man has a reputation beyond reputeHi_D_Ho_Man has a reputation beyond reputeHi_D_Ho_Man has a reputation beyond repute
What sound source are you using?
U will need an outboard module or a vst instrument .
Tapeit? it seem i learn of a new plug in every other day!
HDHM - http://www.myspace.com/kbdagrownup The Temperature Of Success Is Cold As Ice
Old 03-07-2004
Newbie
Wink
I am using a Yamaha P-200 Piano and a Nordlead2 Synth
These are going through a Midisport 8x8.....what i,m trying to do is get a pretty good quality transfer from these midi synths into audio(to mix with the guitars,vocals ect)....is there a really basic way to do that?thanks for your replys and help in this matter...can I use Tape- it to turn over the midi to audio?seems I will need some hardware unit,but what is commonly used in a cubase studio setup to do the midi to audio thingy?hehehe...thanks again for any ideas on this.
Belita Adair
Old 03-08-2004
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
You need to hook up a cable from the keyboard audio outs to the line input on the soundcard. Record the audio tracks in Cubase.
If you want better quality you need a good soundcard. Something like the Audiophile 2496 would be a good start if you only need to record 2 channels at a time.
Old 03-08-2004
Newbie
Thumbs up
Thanks so much!
Belita Adair
