Go Back   Home Recording > User Forums by Brand > Roland, Boss, VS Series Forum
Reply    Audiofanzine Roland boss Roland boss News Roland boss Medias Roland boss Tests Roland boss Articles Roland boss User Reviews Roland boss Classifieds Ads
Old 03-05-2004
Mikilama Mikilama is offline
Newbie
Mikilama is on a distinguished road
When recording with the BR-1180, how do u take the reverb sound out?
I have my headphones on and i can hear myself talking, and with a ton of reverb too. I want to not be able to hear my self when im recording
Old 03-05-2004
Jimmy D. Jimmy D. is offline
Junior Member
Jimmy D. is on a distinguished road
Hi Mikilama,
I'm not sure if it's the same, but with the 532 there's a 'loop effects' button you'd press - then using the 'parameter < >' and 'time/value' wheel, the effect (reverb/chorus/doubling) can be rolled back.
Also, on the 532 there is a mic modeling feature (or guitar, depending on the input selected) that can add excess (too much!) color. As you're looking at the time-level display that comes up when you turn the thing on - you can hit the 'parameter < >' so that the cursor is on the 'MIC' text in the upper right (or wherever the MIC effects field is on the 1180) - then turn the 'time/value' wheel to choose the number that has the least color. The first method should work to remove the excess reverb, provided the 1180 is at least similar to the 532.
Hope this helps!
Jim
JD
Old 05-31-2004
ecktronic's Avatar
ecktronic ecktronic is offline
Mr Mix and Master Man.
ecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond repute
YOU have to listen to yourself when recording. This is a BIG let down of the BR1180. It makes it hard to record drums as the sound of the drums are going through the headphones and also from the drums themselves so you canny really hear the click track, even with good headphones.
Old 11-19-2004
zipperhead zipperhead is offline
Newbie
zipperhead is on a distinguished road
Press 'Reverb' over fader #4, touch the button at the bottom of the channel you're using, and use the wheel to dial it down. Also note that when you mix down onto channels 9/10, it automatically adds rev. to THOSE tracks. After mixing down, I go to Reverb again, go to 9/!0, and turn the reverb level to off, or you end up with more wet sounding tracks than you meant.
Old 11-19-2004
72fender's Avatar
72fender 72fender is offline
Dedicated Member
72fender has a reputation beyond repute72fender has a reputation beyond repute72fender has a reputation beyond repute72fender has a reputation beyond repute72fender has a reputation beyond repute72fender has a reputation beyond repute72fender has a reputation beyond repute72fender has a reputation beyond repute72fender has a reputation beyond repute72fender has a reputation beyond repute72fender has a reputation beyond repute
Unplug the mic.
