Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 03-04-2004
weatherman28us weatherman28us is offline
Newbie
weatherman28us is on a distinguished road
bouncing tracks 788 HELP!
Will someone please tell me how to bounce tracks on a 788 simpler than the man. does its sounds easy but I get lost every time. thank you
Old 03-06-2004
trigger's Avatar
trigger trigger is offline
Junior Member
trigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond repute
Assign the tracks you want to bounce to the Main Mixer (Press & Hold the TRACK button and Press and release the SELECT button for each track you want to bounce.)
Have the STEREO light ON in the monitor section. Hit play - set levels, panning, EQ, etc. on those tracks the way you want.
Now turn the STEREO light OFF and turn the CUE light ON (so you'll hear what's being recorded)
If you have both the STEREO Light ON and the CUE light ON you'll hear BOTH what's being played back and what's being recorded at once and mixing will be impossible.
Now you need to assign the STEREO BUSS to two tracks to record to. (Press & Hold the STEREO button and Press & release the SELECT button for the two tracks you want to record to...in this case we'll pick tracks 7/8)
Arm tracks 7/8 and bring the Fader for 7/8 up to a good record level.
Hit record & play and you are recording your bounce.
You can do mono bounces, you can bounce from any track to any track, you can do stereo bounces(like above), there's just a lot of freedom there.
Remember::::Odd channels are left side info and even channels are right side info. SO, if you try to bounce channel 1 panned hard left to an even channel, that information will not record.
And since Version 2.0, you can 'pre-master' all eight channels and clone the stereo master to two virtual tracks and bring those into the main mixer for playback. I've not BOUNCED since.
Let me know if you have problems and we'll work thru them!
Old 03-06-2004
Newbie
thank you I'll give it a try
