mackie monitors
i have a question about monitors. at the moment i am mixing with headphones.....and not very good ones at that. so, i need something. i record mostly rock. and i was thinking about either some alesis, event, or maybe the low end mackies. although, i heard those catch on fire. heh. so, what do you think?
Search all the threads for "mackie" and you'll find some good monitor threads. I'm in a similar position to yourself, looking for monitors. Searching the threads helped out quite a bit and I've decided to go for the M-Audio BX8s.
Keep in mind that the monitors are probably the most important thing you'll use, so don't short change yourself when buying your first pair. Really save up some money (put off buying other gear) and research this. You can make a great recording with an SM57 and great monitors. You'd have a hard time making a great recording with a Neuman mic and crappy monitors (or headphones). If you can't hear what you're recording, how do you really know if you're recording the right thing?
I would assume that it's a "marketing" thing, but I truly can't understand why they aren't much more popular... Maybe they should increase their list prices... John Scrip - www.massivemastering.com |
Thank you. This is one of the first kind posts from a mastering engineer I've read on these threads.
Perhaps out of your price range...but the HR824's are awesome ! |
I'm about 1 inch away from coveting a set of these...thanx |
Have had mine for a month or so. They occupy the same space as my old monitors and the upgrade has made mixing MUCH easier not to mention tracking. My old ones were Alesis Point 7's. They lack ALOT and made mixing almost a chore,..ya know. I saved and saved for the Mackies. I only wish I could have got them sooner. Excellent,..... excellent monitors! Take 'er easy,.. Calwood |
same here..... 824's ......... nothing but good stuff from using them.
If money wasn't a big problem, does anyone have any opinion on a 824 vs BX8 comparison. If the 824s are a whole lot better, I'd rather save the extra money and do it right the first time, but I've read nothing but goodness about the BX8s.
They were nice but the HR's deliver much more power and low end and the clarity I find unmatched at this point. I'm not an expert on monitors but I have found this will more than likely be the last upgrade I need. |
#12
what do you yall think about the m-audio BX-5's? a little cheaper than the other ones.
#13
Thanks for the info Mackie lovers !
I guess I'll have to consider the BX8 due to Massives' credentials too...trying to keep the list of possibilies down to 3 models - not too big. |
#14
So compromise and get the Mackie HR624's.
They're also great! Like wearing headphones without wearing headphones!
"Oh yeah, life goes on...long after the thrill of living is gone." - John Mellencamp |
#15
I'm not much of a monitor expert, but a buddy has the 824s and I will definately be buying a set of those if I can ever afford it. The main thing that got me when I took a mix over to his house was that all of a sudden I could hear what was going on in the really low end of my tune. I think they are a great all around monitor but the extreme lows those things had for their size were quite impressive.
#16
#17
the bx8s are nice from wat ive read... but if i have a chance to pick up some bx5s for 250 new... should i do it? or wait and get the 8s ? wats the diff. besides more wattage?
lbcstudios |
#18
#19
#20
Yeah, the reason I say that is because after spending about $300 to treat my room (built bass traps, panel absorbers) I now have much better low end response. Previously, I blamed it on my monitors - Yorkville YSM-1's - but I think my money was much better spent that on a new pair of monitors. The thing is, even though YSM-1's bass response tails off towards 40Hz or so, the frequency ranges that give us that low end thump are not really the low lows, but more the ~100-300Hz range where room modes can have a huge effect.
#21
yeah, makes two. my monitors sounded different after doing some wall stuff. you can this cheap too...highly recommend looking into before going monitor shopping again, and again, and again. my bass traps added rumble to the next room tho..... but fhk? my room sounds better!!! ![]() |
#22
Anyone have any experience with Roland DS90a monitors?
#23
I'm not saying that the Mackie's aren't good, I just couldn't get a mix to translate properly after a few hundred hours of use. With the BX8's, the first mix I pulled through them was just how I expected. Lemme explain my problem with the Mackies - I've had a few e-mails on this.. When I play a good mix on the Mackies, it sounds great. When I play a good mix on the BX8's, it sounds GOOD. When I play a great mix on the Mackies, it still sounds great. BX8's, great. Bad mix Mackies, good. Bad mix BX8's, horrendous. So essentially, I find the Mackies a bit hyped... Not nasty hyped, but not exactly natural, either. If were getting a set for sheer listening, it'd be the Mackies, hands down. But when a "good" mix sounds "great" through monitors, I'm no comfortable with that. I need an "okay" mix to SOUND "okay" - Anything more, and I'm fooling myself. If there's going to be a lean to either side, I want to lean towards "plain" - Make sense? Again, just my two cents, your mileage may vary, etc... JS |
#24
MACKIE MONITORS
I use the mackie 824's.They've been very really good monitors.A bit spendy.Do you read Pro Audio Review?In every issue they have a article called Single Slice.It tells how they recorded the music.And also tells the gear they used.VERY USEFUL.It's also a preference.Go to your local pro music store.They should help.Good luck!!!
#25
I use the Mackie as well as the 12" Mackie Sub. The key to great sound was when I installed a DAC1. The new Tapco guys are cheap and sound pretty good to
