Old 02-24-2004
Doink Doink is offline
Junior Member
Doink is on a distinguished road
DIY phantom power unit
I've been looking at building a phantom power supply. Is it as simple as taking a wall wart, chopping the end off, and connecting the + and - leads to the + and - leads of the cable going to the mic?
Old 02-24-2004
The Green Hornet The Green Hornet is offline
Been Here, Posted That
The Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond repute
Talking
Yo Doink:
If and when you do this chopping and taping, make sure you're not standing in water when you grab the mic.
Green Hornet
Old 02-24-2004
Harvey Gerst Harvey Gerst is offline
Huh ???
Harvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond repute
Re: DIY phantom power unit
No, it's not that simple.
First of all, you hafta find a wall wart that'll put out 48 volts of clean DC. then you hafta limit the current output to about 10ma by using a pair of closely matched 6.8k resistors (connected to the 48V DC "+" lead) and feed that (coming from the those 2 resistors) to the two signal leads of the mic (pins 2 and 3). Finally, you'll connect the "-" lead of the supply to ground (pin 1).
Then, you'll need a couple of 10mfd blocking capacitors in series with pins 2 and 3 (between where you added phantom power and the mixer) to prevent the DC signal from hitting the mic preamp or mixer. Some mixers already have those capacitors in place.
