Go Back   Home Recording > User Forums by Brand > Roland, Boss, VS Series Forum
Reply    Audiofanzine Roland boss Roland boss News Roland boss Medias Roland boss Tests Roland boss Articles Roland boss User Reviews Roland boss Classifieds Ads
Old 02-22-2004
pM of impk21.co pM of impk21.co is offline
Senior Member
pM of impk21.co is on a distinguished road
DR-770 MIDI Quesion....
I have an mc-909 sampler which has a midi sequencer in it. But personally, the drums seem to suck, what I would like is to use the sounds off of my DR-770.
What I would like to do is program the midi sequence on the sampler and then have the sampler play the instruments from the 770. I can set each midi track on the sampler to play either the internal sound or midi device or both. The trouble I am running into is how to select the instruments being played by midi on the 770. When I run the midi into the DM, it plays just a whistle or some unique percussion, I want to assign the instrument. Make since? ANy help would be dope. Thanx, pm
pm of
www.impk21.com
Old 03-01-2004
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
On the sequencer there should be a way to assign a program change on the channel that is playing. If not you will have to manually select the patch on the drum machine before playing the sequencer.
If it is playing the right kit but not the right notes then you need to see what notes each drum is assigned to on the DR770 in your manual. Then you have to use those notes when you program the sequencer.
