Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 02-20-2004
sackbutcharlie sackbutcharlie is offline
Newbie
sackbutcharlie is on a distinguished road
424 MKIII - What else do I need?
I am hoping for some guidance. I used to be a musician but have not been in a recording studio in 20 years. I am interested in recording a family member who sings and plays acoustic guitar. I am thinking about getting a 4-track cassette. My questions are: #1 - Can I run a mike right into this or do need any type of pre amp? #2 - It looks like the board is built in, am I correct that no other mixer is required? #3 - Can the built-in board also be used to mix output to a 2-track master (or cassette or CD or whatever)?
What I have read makes it sound like all I need s the 424, a couple of good mikes, and a tape or CD recorder to mix down to (plus monitors, headphones, etc.). Is that right?
Thanks!
Old 02-20-2004
ronsmith's Avatar
ronsmith ronsmith is offline
Junior Member
ronsmith is on a distinguished road
424
thats all you need. I own a424 and it has built in preamps. its a complete studio. Just plug in your mike and start recording. Then mix your tracks down to stereo on a cassette deck. Have fun!
Old 02-21-2004
Mark7's Avatar
Mark7 Mark7 is offline
Human 2.0
Mark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond repute
If you have any condenser mics you'll need a Phantom Power source as the Tascam Portastudios don't provide it. But you should be able to find one easily enough.
Orbiting this at a distance of roughly ninety-two million miles is an utterly insignificant little blue green planet whose ape-descended life forms are so amazingly primitive that they still think digital recording is a pretty neat idea.
Old 05-18-2004
HeyHeyMyMy's Avatar
HeyHeyMyMy HeyHeyMyMy is offline
Red Member
HeyHeyMyMy has a reputation beyond reputeHeyHeyMyMy has a reputation beyond reputeHeyHeyMyMy has a reputation beyond reputeHeyHeyMyMy has a reputation beyond reputeHeyHeyMyMy has a reputation beyond reputeHeyHeyMyMy has a reputation beyond reputeHeyHeyMyMy has a reputation beyond reputeHeyHeyMyMy has a reputation beyond reputeHeyHeyMyMy has a reputation beyond reputeHeyHeyMyMy has a reputation beyond reputeHeyHeyMyMy has a reputation beyond repute
excellent...
This is exactly the question I wanted to ask, excellent. I do have one more little thing to ask: should I use some sort of compressor on my signal going in to the MKIII, more specifically, on vocals? I am planning on recording an acoustic album, with just my voice and my guitar. I have an old Ibanez Compressor/Limiter that I used to use for electric guitar, any chance I could use that? It only has quarter inch inputs and outputs, much the same as all stomp boxes. Any advice would be great, thanks a lot!
Old 05-18-2004
Zeekle Zeekle is offline
Junior Member
Zeekle is on a distinguished road
Cool
Hey Hey... Some sort of compressor is always a good idea, but try recording with and then without it. If the difference is to your liking, use the set up you like.. I don't tend to use my compressor with my acuostic, but do use it for vocals. Get a reverb unit too, for both the guitar and vocals, add a little and you can't go to far wrong.
Zeek
Old 05-18-2004
HeyHeyMyMy's Avatar
Red Member
Hey Zeekle, sounds good, I will look into a 'verb unit. As for compressors, I would assume I can't use an effects loop on mixdown to compress vox right? From what I've read I have to use it on my initial signal going in to the mkIII. If so, does anyone have any recommendations as to cheap compressor units I could get for the vocals? Thanks a lot.
Old 05-18-2004
Junior Member
I use a digital recorder so I record some sources 'dry' then bounce them onto another track and add the Fx then via the Fx loop (aux sends, returns) (reverb, compression, whatever) I can then remix it if I wish.
Theres a thread on The Rack.. on this BBS .. all about compressors etc, good reading.. go have a look..
Zeek
Old 05-18-2004
HeyHeyMyMy's Avatar
Red Member
beautiful, thanks.
Old 05-18-2004
radiorickm's Avatar
radiorickm radiorickm is offline
Senior Member
radiorickm is on a distinguished road
if you wanted
technically, you can use the loop. it's not the best way to go. but you can plug a mike into ch1, and use the efx sent to put the signal out. go to the compressor and return it into one of the stereo returns 5/6 or 7/8.
not the best way to do it but you can
Old 05-18-2004
chessparov chessparov is offline
Three Thousand and Counting
chessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond reputechessparov has a reputation beyond repute
Used Ashly compressors can run under $100 and are quality gear.
Chris
Old 05-20-2004
DigitalSmigital's Avatar
DigitalSmigital DigitalSmigital is offline
A slice of analog pie?
DigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond repute
The reason you should not use the fx loop to compress a signal (or to EQ)when mixing down on the 424 is:
the effects send is post fader, meaning that the signal coming from the channel strip goes to the main mix and the fx loop. It does you little good to eq and/or compress a portion of the signal.
  #12
Old 05-20-2004
The Ghost of FM's Avatar
The Ghost of FM The Ghost of FM is offline
French Mofo
The Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond repute
Excellent point, DS.
Or to put into layman's terms, it's like trying to shoot a puck with a swizzle stick.
Cheers!
  #13
Old 05-22-2004
Ha! Canadian layman's terms always have something to do with hockey!
For those of you who don't know what a puck is, he means "it's like trying to steal second in a pair of Doc Martins".
