Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 06-03-2000
wawazzat's Avatar
wawazzat wawazzat is offline
Senior Member
wawazzat has a reputation beyond reputewawazzat has a reputation beyond reputewawazzat has a reputation beyond reputewawazzat has a reputation beyond reputewawazzat has a reputation beyond reputewawazzat has a reputation beyond reputewawazzat has a reputation beyond reputewawazzat has a reputation beyond reputewawazzat has a reputation beyond reputewawazzat has a reputation beyond reputewawazzat has a reputation beyond repute
Wink
I have this song I've been working on, kinda mid 60's sounding, and it just begs for a tambourine track. My first efforts have been less than stellar.
Does anyone have any cool tips on tracking a tambourine? I sure would appreciate some expert advice....
wawazzat?
the widely ignored
Old 06-03-2000
DALtune DALtune is offline
Senior Member
DALtune has a spectacular aura aboutDALtune has a spectacular aura aboutDALtune has a spectacular aura about
Wink
I like to record the tamborine with a condensor placed at playing height (waist high or so) and set the level so it registered where desired when the tamborine is about a foot away. That's for an open tamborine, like a Rythem-tech. A headed tamborine I usually mic a little closer.
I usually like to keep it down in the mix with a generous amount of reverb so it fills in the drum track.
Remeber to keep your wrist stiff when shaking, otherwise you won't get an even tone.
Old 06-03-2000
wawazzat's Avatar
Senior Member
Wink
Thanks DALtune, I hadn't tried anything like that yet. Sounds like a good place to start. Unfortunately, I don't have an LD condenser. Should I modify the deal if I use a SM58/57?
wawazzat?
the widely ignored
Old 06-03-2000
kristian's Avatar
kristian kristian is offline
1K Silver Member
kristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond repute
Thumbs up
basically yea. use the 57, its the 58 minus the build in popper stopper. and for future reference, if you play acoustic, sing, and like tambourines, and track live drums... save up for a month or so, shell out $200 for an NT-1.. and you will have the nex few levels up of sound quality.
Old 06-03-2000
wawazzat's Avatar
Senior Member
Wink
It's a deal. I've been looking at the Rode's. Probably should be next on the list, then good monitors. Thanks a lot.
wawazzat?
[This message has been edited by wawazzat (edited 06-03-2000).]
Old 06-04-2000
Senior Member
Wink
I used to use a 57 and had good results.
That was when I had a Porta 2 and would put the tamborine on the floor on a towel and tap it with my foot while using another 57 to record acoustic guitar.
The good ol' days...
Old 06-05-2000
Mooseboy Mooseboy is offline
Junior Member
Mooseboy is on a distinguished road
Wink
Hey, wawa-
If you don't need the sound of the jangles in between percussive hits, use DALtune's suggestions, but hold the tambourine steady, and just move the hand that you're hitting it with.
It gives you a whole different sound- especially because the jangles ring more in between hits.
Old 06-05-2000
wawazzat's Avatar
Senior Member
Wink
Thanks guys, I'll try it this weekend.
The foot tappin' thing too!
It sounds like it could be fun...
wawazzat?
the thread stopper
Old 06-24-2000
John Sayers's Avatar
John Sayers John Sayers is offline
Solar Power!!
John Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond repute
Wink
The problem with tambourines is the excessive transients. If you are using a peak meter it's OK but if you have a VU meter you can only peak the signal to around -20db or the peaks will distort your gear and your tape.
Old 07-10-2000
LongWaveStudio LongWaveStudio is offline
1K Silver Member
LongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond reputeLongWaveStudio has a reputation beyond repute
Wink
yeah, just use an SM57, or a 58 without the shield. increase some of the high end if the tambourine sounds too muddy. an AKG C3000B is great aswell.
Old 07-11-2000
CharlesThomas CharlesThomas is offline
Senior Member
CharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond reputeCharlesThomas has a reputation beyond repute
Wink
Apart from what's already been mentioned, I'd say use some light compression to make sure that you don't overload the input of your deck. Tambourines are REALLY dynamic and a little compression, peak limiting or both can help keep things in check.
With a tambourine, you're mostly interested in the high-end part, so I usually roll off as much low end as I can. You'll have to experiment and see how much of the "smack" of hitting the tambourine you want to keep. This smack will be in the mids. If the tambourine is mostly alone and is partly responsible for keeping time (in a section without drums, for example), you may need more of these mids. If, on the other hand, it's part of a thick mix and is just there for high-end "jangle" (like the chorus of a poppy song), you can afford to lose more of the mids .
Tambourines vary greatly in terms of the tone they produce. The D-shaped Rhythm Tech tambourines I've used are really dark and "clanky" sounding, but I have an LP tambourine that I bought that's VERY bright and really gets a great sound. Depends on the sound you're after, but I like a really bright tambourine.
Just a little light gating can help clean up those unwanted jangles between hits if you're only hitting on "2" of the measure, for example. Sometimes in sparse parts like that it's hard to keep your hand still enough and unwanted jangles can show up between hits.
I also highly recommend condensers for tambourine, and I noticed a HUGE improvement in the tambourine sound when I went to a stand-alone mic preamp as opposed to just running into the preamps of my mixer. I was getting a fairly "squashed" sound from the built-in preamps, but the ART Tube Pac preamp I bought gives me a much more "airy" or "open" tambourine sound. I think it's because tambourines have a very sharply peaked sound spike pattern that's VERY dynamic. It's hard for a cheaper mic preamp to capture the nuances in something that dramatic.
Good luck!
Charles Thomas - Who did a LOT of tambourine recording this last Fall.
[This message has been edited by CharlesThomas (edited 07-11-2000).]
  #12
Old 01-27-2009
Monkey Allen's Avatar
Monkey Allen Monkey Allen is offline
creeping moses
Monkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond repute
I want to record some tambourine action tomorrow...and a shaker too. I supopse some of the same techniques can be applied for shaker too? lol I think I was abuot 6yo when this thread was statred.
the park job in 7a
  #13
Old 01-30-2009
antichef's Avatar
antichef antichef is offline
unfocuser
antichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond repute
Now that we have space age tambourines, that old stone age stuff doesn't apply anymore.
  #14
Old 01-30-2009
iownrocknroll iownrocknroll is offline
Dedicated Member
iownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond reputeiownrocknroll has a reputation beyond repute
tamborine, shakers, hand claps, floor stops, woahs!
simple production at it's best....love it all
  #15
Old 01-30-2009
drossfile's Avatar
drossfile drossfile is offline
custom title FAIL
drossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond reputedrossfile has a reputation beyond repute
thisi thread is every bit as relevant today as it was NINE years ago.
dross
