Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 02-18-2004
TamaSabian's Avatar
TamaSabian TamaSabian is offline
Peruvian skin beater
TamaSabian has a reputation beyond reputeTamaSabian has a reputation beyond reputeTamaSabian has a reputation beyond reputeTamaSabian has a reputation beyond reputeTamaSabian has a reputation beyond reputeTamaSabian has a reputation beyond reputeTamaSabian has a reputation beyond reputeTamaSabian has a reputation beyond reputeTamaSabian has a reputation beyond reputeTamaSabian has a reputation beyond reputeTamaSabian has a reputation beyond repute
Snare side head
How often do you change it?. This is the second head that I have to change because it´s broke from the side near the snare strainer. My snare is a 8 lug tama rockstar, I use remo heads, 14" coated ambassador on top, diplomat hazy on bottom. I tune top higher than bottom, do you think that´s the reason why I break the snare side head, maybe my the batter is too high in pitch.
What othe heads would you recommend for snare side??.
Thanks
Tama
Old 02-18-2004
kesterdevine kesterdevine is offline
Senior Member
kesterdevine has a reputation beyond reputekesterdevine has a reputation beyond reputekesterdevine has a reputation beyond reputekesterdevine has a reputation beyond reputekesterdevine has a reputation beyond reputekesterdevine has a reputation beyond reputekesterdevine has a reputation beyond reputekesterdevine has a reputation beyond reputekesterdevine has a reputation beyond reputekesterdevine has a reputation beyond reputekesterdevine has a reputation beyond repute
Question a possibility
You might wanna check closely to make sure you don't have a rough edge on the snare itself or something that might be physically puncturing/cutting the head?
I've been drumming for a LOOOONNGGG time, and I don't think I've ever broken a bottom head.
Just an idea.
Old 02-18-2004
mikeh mikeh is offline
2.5K Gold Member
mikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond repute
I agree that there are very few reasons a bottom head should break. Either the snare caused a tear (rough edge or missing snare strand) - or the basket of the snare stand has something in contact with the head - or some other abuse.
I normally change my bottom head on the snare every year or two (depending on how "dead" the drum starts to sound - but have never had to change it due to a tear.
Old 02-18-2004
TamaSabian's Avatar
Thanks mike and kes, I think you´re right, my snare is rusty on the resonant side, when it makes contact with the head it finally tears or puncture the head.
Is there another snare side head thicker than diplmat hazy, what about ambassador´s
Tama
Old 02-18-2004
Rimshot's Avatar
Rimshot Rimshot is offline
Force of Nature
Rimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond repute
You choose your snare side head for the sound you want to get not for durability. A very thin snare head with good contact to sn average width of good snare wires will give you a more sensitive snare. I usually tune my snare side head a half step higher than my batter head.
I have this one snare that is a 10 ply maple with 45 degree bearing edges and I wanted it to be a very sensitive snare. The problem was it was TOO sensitive, so I had to replace the snare side head with a thicker head just to tame it a bit.
I agree with all of the others. The only time that I've had to replace a snare side head was when it got tired. You MUST have something else going on there, either bad snare wires (if they're rusty, it's well past time to replace them), an issue with your stand or possibly, a roughness or a sharp spot on the bearing edge.
Have you checked and smoothed down the bearing edges on your drums? Most drummers don't realize than things can get in there through the vents and eventually lodge between the skin and the bearing edge. It will pay you to open up your drums every once in a while, clean the interior out and check and attend to the bearing edges, replace the heads and re-tune. Think of it like a tune up and an oil change for your car.
"There is no expedient to which man will not resort to avoid the real labor of thinking."
-Sir Joshua Reynolds
Old 02-18-2004
TamaSabian's Avatar
Thanks rimshot, I think I must check inside my snare....
I was looking through the snare side head and I can see some dust and lodge that has been there for a while, I need to clean and check the bearing edges they must be a little rusty too. I need to save for another snare.
Thanks
Tama
Old 02-18-2004
Drummer4Life05's Avatar
Drummer4Life05 Drummer4Life05 is offline
Say Something Smart!
Drummer4Life05 is on a distinguished road
Also just make sure you're not crankin' the bottom head.
Bottom heads are very thin and don't stand up to very much tightening.
Old 02-25-2004
MapexSabian MapexSabian is offline
Newbie
MapexSabian is on a distinguished road
Remembering of course that remo diplomats are bloody thin heads. i don't know if they have diplomats and diplomat snare sides but they are still hugely thin.
try an ambassador snare side. they are awesome.
on my snare I have a CS dot batter over ambassador snare side
Old 02-26-2004
Greykitkat36 Greykitkat36 is offline
Senior Member
Greykitkat36 is on a distinguished road
I dont have a very good snare, but I have good heads to make up for it. I have an Evans G1 on top, and an Evans Hazy 300 on the bottom
Old 02-27-2004
Blink 182 Blink 182 is offline
Senior Member
Blink 182 is on a distinguished road
only thing i can think of is over tightening. i had a problem once when i didnt put the bottom head in correctly, and i tightened it alot and warped the skin. it was a 12 inch snare though, so i dont know.
