Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 02-15-2004
Whyte Ice Whyte Ice is offline
The Next Vanilla Ice
Whyte Ice is on a distinguished road
Problem with Sustain Pedal
I'm having a problem with my sustain pedal right now. Whenever I don't press on the sustain pedal, the notes are sustained but when I press on the sustain pedal, the notes stop. It's working in reverse. I want the notes to sustain when I press and hold it down, not when I let it up. I'm using an M-Audio Radium 49 controller and I've read through the manual and M-Audio's website a few times to see if there is any setting to change but nothing.
The sustain pedal works on another keyboard of mine fine, it works the way it should but not on this. I was thinking that it might be my pedal. It's a very cheap generic one and doesn't look like the kind used on pianos.
Any help with this problem would be appreciated.
Old 02-16-2004
mikeh mikeh is offline
2.5K Gold Member
mikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond repute
This is a common problem. I don't remeber the technical term - but some keyboards do work in reverse. Normally the keyboard has a parameter that you can change. Some pedals have a switch that can reverse the pedal action.
If you can't find a parameter adjustment on the jeyboard or the pedal - you will need a different pedal.
Old 02-16-2004
brzilian brzilian is offline
2.5K Gold Member
brzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond repute
It is called polarity. If the keyboard has no settings to change polarity, you will need to buy a new pedal.
Old 02-17-2004
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Or reverse the wires on the plug.
Old 02-17-2004
How would I go about doing that?
Old 02-17-2004
2.5K Gold Member
Then it won't work with the other keyboard.
Old 02-17-2004
I'm just gonna buy a new sustain pedal anyways. Tired of this cheap POS one I have now. It's always creaking when you play with it and looks like a Ghostbusters accessory.
Thanks for the help guys.
Old 02-18-2004
don4777 don4777 is offline
Newbie
don4777 is on a distinguished road
This isn't a polarity problem. Some footswitches are "normally open", others are "normally closed".
normally open: the switch contacts are open until you hit the switch.
normally closed: the switch contacts are closed until you hit the switch.
Both of the above switches are "momentary" switches. They change state only when pushed. There is a third type that changes state every time it is pushed. Push once - it's on. Push again - it's off. This type wouldn't be used for a sustain pedal but are popular for turning effects on and off or switching amp channels.
Some equipment will sense whether the switch is open or closed when it powers on. It will treat that as the normal condition. Most equipment needs to have the proper switch. Some footswitches are selectable. They can be set to be "normally open" or "normally closed". The type you need should be documented in your keyboard manual.
Don
Old 06-25-2004
dumelara77 dumelara77 is offline
Newbie
dumelara77 is on a distinguished road
problem with sustain pedal in Cubase
The notes hold and stick when using the sustain pedal. Any help?! When I use the pedal, it registers in Cubase that I'm actually playing notes (in audio!). Also, when I use the sustain function in Cubase, the notes sometimes stick and hold as well. Do help me somebody!.Thanks
Old 06-29-2004
tedluk tedluk is offline
Force of Nature
tedluk is on a distinguished road
Talking
GET SONAR!!
Old 06-29-2004
Jon Doe Jon Doe is offline
Newbie
Jon Doe is on a distinguished road
Try holding the pedal down when you power up the keyboard. That should reverse the polarity again. Anyway, that's how my M-Audio MK461c works ...
