Micing acoustic guitar
Okay, I'm having difficulties getting a good sound of my acoustic guitar. Here's my set up:
AT 4033 > Focusrite Penta Compressor > Motu 828 > Logic 6.3. I ran a frequency analyzer on it, and I am not picking up enough high frequencies...there's too much muddy "booming". Almost "buzzy".... I don't want to EQ unless I am totally f**ked. The guitar sounds nice to my ears, but recording sounds terrible. I am pointing the mic where I have always pointed it in the past, with good results previously....at the 12th fret only slightly tilted towards the body of the guitar, 6" out or so. I am using D'addario XL's...maybe I should have strung it up with L's. Help. thanks |
I would think that your gear and signal path should give you a good sound. Certaintly your mic position is what 90% of people would start at.
When you say you've always gotten a good sound before - was it using the same gear in the same room?? I do find that when I record accoustic instruments in my studio (not an ideal accoustic space) I often have to find a different "sweet spot" where I get a good capture of all frequencies for different instruments. I have actually found that two different accoustic guitars sounded better in different parts of the room. Not to state the obvious, but if you are not getting the high end - you need to look at the age and type of strings (which you have already questioned). |
Good suggestions, If you normally string up with lights and you put on extra lights, without adjusting the guitar, the buzzing is probably the strings buzzing on the frets. I had a similar problem with a 12 string. It sounded good from the playing position, but had a terrible buzz when I listened back. Also, with my limited mic selection, I usually have to roll off a ton of low end on acoustic guitars. |
These are excellent suggestions...thanks.
Working in my living room, which has nice wood floors and great ambience. I will try miccing with a Rode NT4 I have first; if that doesn't work, I'll change strings to lite. I'll also try changing locations in the room... |
Have you tried bypassing the compressor to see if it makes a difference in the frequency's being picked up ?
What I mean is what if the compressor is compressing the higher frequencies ? Is that even possible ? |
All:
Thanks for all the advice. The problem turned out to be two-fold. The problem was my guitar strings. I changed to Light (starting at .11) and this made all the difference. Also, I shouldn't have been monitoring on headphones and I couldn't get a good reference to what was actually being recorded. The AT 4033 worked just fine. This helped too. Thanks again. |
