Old 02-10-2004
christiaan's Avatar
christiaan christiaan is offline
1K Silver Member
christiaan has a spectacular aura aboutchristiaan has a spectacular aura about
What IS the proper way to wrap cables?
After reading http://homerecording.com/bbs/showthr...hreadid=112248 I was wondering..
Old 02-10-2004
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
It's hard to explain without being there in person but this guy gives a good description for mic and instrument cables. http://onstagemag.com/ar/performance_show_go/
coil the cable into a loose circle. Starting with the cable flat on the floor, hold one end in your left hand, and then use your right hand to loop the cable into a circle roughly 15 to 18 inches in diameter. As you wind the loop, gently twist the cable clockwise with the fingers of your right hand, and it will smoothly curve into place. If you store the resulting circle of cable flat (with velcro cable ties to keep it together, if desired), it will be kink-free and flexible each time you use it.
For large cables and snakes you usually coil them on the floor. Start a circle a few feet in diameter on the floor then pull the snake towards you and do the same thing as above.
For some heavy cables and really long mic cables there is the over/under. It's the same as above except every other coil is flipped under the last one. It's easier to show in person but it's like trying to describe a sailors knot in writing. The idea is that it makes it easier to pull a cable from one and and not have it tangle up on you as you stretch it out.
Once you get good at it you can coil up and tie off a 50ft mic cable in about 10 seconds.
Old 02-10-2004
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
One of the big things is not to FIGHT with the cable. Cable comes OFF of coils at first. It remembers and wants to return to its original shape. That's why the "hand-to-elbow method turns cables into a twisted wreck of their former selves.
Coil gently, manipulate the cable between the forefinger and thumb as you're coiling. You'll learn to feel which way the cable wants to go and you can help it along.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 02-10-2004
christiaan's Avatar
1K Silver Member
Ok, makes a lot of sense. Thought it would kind of be like that but I needed to be sure that I wasn't overlooking some vital issue.
I have a small recording gig on location soon with someone with even less experience helping me out (my slave) and I want to set a good example.
Thanks guys.
Old 02-10-2004
Armistice's Avatar
Armistice Armistice is offline
I am not the messiah...
Armistice has a reputation beyond reputeArmistice has a reputation beyond reputeArmistice has a reputation beyond reputeArmistice has a reputation beyond reputeArmistice has a reputation beyond reputeArmistice has a reputation beyond reputeArmistice has a reputation beyond reputeArmistice has a reputation beyond reputeArmistice has a reputation beyond reputeArmistice has a reputation beyond reputeArmistice has a reputation beyond repute
Same way you coil up a garden hose - you'll understand then what Massive Master says about not fighting the cable!
Old 02-10-2004
crazydoc's Avatar
crazydoc crazydoc is offline
Master Baiter
Location: Please forgive me. I don't mean to be a prick, but I guess I am.
crazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond repute
Hard to explain, yes.
"As you wind the loop, gently twist the cable clockwise with the fingers of your right hand, and it will smoothly curve into place."
If you do this for the first loop, then twist counter-clockwise for the next loop, it will form under itself as you catch it with your left hand. Then the 3rd loop is clockwise, the 4th counter, etc. alternating every other loop.
Yup, hard to explain.
Plus, I'm left handed, so it's just the opposite for me.
I'm going through a difficult period - it's called life
Old 02-10-2004
kid klash's Avatar
kid klash kid klash is offline
The original Mr. Nice Guy
kid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond reputekid klash has a reputation beyond repute
The technique is called "over-under". If you do this, your mic cables should last longer than you do.
Old 02-10-2004
Tartan_Keyboard Tartan_Keyboard is offline
Newbie
Tartan_Keyboard is on a distinguished road
I always wondered if there was a "right way" of packing cables
^***Tartan_Keyboard***^
Old 02-11-2004
donkeystyle donkeystyle is offline
This place sucks now. Bye
donkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond repute
there's no "right way;" just better ways.
This place is garbage.
Old 02-11-2004
mrface2112 mrface2112 is offline
Thread Killer
mrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond repute
<< there's no "right way" >>
i respectfully and totally disagree. cables have a memory, which as MM said, usually comes from the original spool/coil the cable came on. if you try to coil a cable against that memory, you will eventually work the cable back and forth, which weakens the cable, causing wires in the strands to break. break enough of the wires in the strands, and you'll lose signal quality. why use better cables? partly b/c they stand up to repeated coilings and twistings.
the "proper" way to coil cable is indeed over-under. simply put, it re-coils the cable in the "same" way it was coiled when it came off the original spool. it follows the cable memory.
if you ever did any lifeguard duty/training as a teen, it's the same way that you coil the rope on the floatation ring that you would throw out to a drowning swimmer. if you try to do any other cable wrap other than an over-under on that rope (such as an elbow wrap), 1) the rope will get all twisted on itself, 2) the ring won't throw straight, and 3) your victim will drown. you get to be extremely proficient at a very FAST over-under, b/c if you miss the victim, you've gotta re-coil and re-toss and it only takes a second for someone to go under.
so don't fight the cable--it will pretty much coil itself if you pay attention to it. it just takes a little practice.
cheers,
wade
Old 02-12-2004
dirtythermos dirtythermos is offline
Dedicated Member
dirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond repute
Another advantage of over-under is that you can throw it and it will uncoil in the air - tangle free.
Or you can set the coil at the vocalist's feet, and when they pull the mic off the stand and walk across the stage, it will uncoil - tangle free - behind them.
Of course, these are live sound applications more than studio, but it's still the "right" way to treat your cables.
  #12
Old 02-12-2004
Mr. Moon's Avatar
Mr. Moon Mr. Moon is offline
Force of Nature
Mr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond reputeMr. Moon has a reputation beyond repute
Same way we used to wrap up ski lines when I was on a waterski team many moons ago ...so to speak.
-mr moon
Intel Core 2 QUAD Q6600
Intel D975XBX2
2 GB OCZ 800MHz DDR2
RME FireFace 800
Windows 64 Pro
  #13
Old 02-12-2004
i still say there's no right way. i totally understand and respect what you're saying though. i also think you're right. I too over;under my cables.
i stand by my original comment though. No right way, just better ways. i guess it would be better said..........no right wa; just A better way.
  #14
Old 02-16-2004
faderbug faderbug is offline
faderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond repute
'What IS the proper way to wrap cables?'
i let my assistant do it
  #15
Old 02-16-2004
Light's Avatar
Light Light is offline
Born in the Light ofStars
Location: Creating saw dust at rapidly increasing levels
Light has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond repute
Over-under, over-under, over-under, over-under, over-under, over-under, over-under. There is no other proper way to coil a cable, if you want maximum cable life. When you coil them all over, so to speak, you twist the wires inside of the cable, which causes the connections to break. If you over-under your cables, each turn compensates for the twist of the last turn, and protects your cables. I find it impossible to describe how to over-under, but if you know any professional video guys, they will know. They are obsessive about over-undering their cable, as co-ax is so stiff it will just about explode if you try to wrap it any other way.
Light
"Cowards can never be moral."
M.K. Gandhi
  #16
Old 02-16-2004
foreverain4 foreverain4 is offline
1K Silver Member
foreverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond repute
the band i played in in high school just bought a garden hose reel from the local hardware store. wind one up, connect the next one end to end, wind it up, etc. you have to be careful you dont pull too hard on the ends, but we never had to mess with untangling cables.
Lynn
www.trhrecorders.com
  #17
Old 02-18-2004
noisedude's Avatar
noisedude noisedude is online now
Alleged Moderator
noisedude has a reputation beyond reputenoisedude has a reputation beyond reputenoisedude has a reputation beyond reputenoisedude has a reputation beyond reputenoisedude has a reputation beyond reputenoisedude has a reputation beyond reputenoisedude has a reputation beyond reputenoisedude has a reputation beyond reputenoisedude has a reputation beyond reputenoisedude has a reputation beyond reputenoisedude has a reputation beyond repute
I'm left-handed and I can't say I've had any problems as yet, maybe my brain is wired wrongly. I sometimes forget that as a left-handed right-footed person I'm supposed to find life really difficult.
  #18
Old 02-18-2004
F_cksia F_cksia is offline
Force of Nature
F_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond reputeF_cksia has a reputation beyond repute
That´s how I´ve learned it
  #19
Old 02-18-2004
crazydoc's Avatar
Master Baiter
Oh, yeah, now it's clear!
  #20
Old 02-18-2004
crazydoc's Avatar
Master Baiter
Originally posted by noisedude
I'm left-handed and I can't say I've had any problems as yet...
Well, you're a limey - the whole damned country is bass-ackwards, so you fit right in.
  #21
Old 02-19-2004
Force of Nature
heheh... yah I thought so.
  #22
Old 02-19-2004
noisedude's Avatar
Alleged Moderator
You're so right. Maybe you should come and sample the United States of Britain yourself sometime.
Do you know that lefties live on average 9 years less than right-handed people? it's a sad truth.
  #23
Old 02-19-2004
glynb glynb is offline
Balladeer
glynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond repute
We lefties don't live as long because we keep getting bumped off by CIA backed counter insurgents...
...oh, you mean left HANDED ;-)
But seriously, on the cables, I used to freak out other members of the band by folding cables and then when small enough tying them in a loose knott. They tend not to tangle up at all like this and you have no problem pulling a specific cable out from the bunch. The down side is that it may in theory weaken the cable, that said I have some guitar cables which are 20+ years old and were always stored using this method and still work fine!
I guess it's a trade off bertween convenience and speed vs prolonging cable life - you make a choice.
Online home
  #24
Old 02-19-2004
Light's Avatar
You get a little piece of tie line, tie it on to one end of the cable, and you coil it properly. I would bet you $1000 I can coil a cable properly faster than you can fuck up a cable 9as you HAVE been doing). Of course, I am a stagehand, and I probably coil more cables in a month than you have, or will, in your lifetime, but none the less, there is no reason to fuck up your cables. You can have convenience and longevity. Just learn how to over-under your cables, and you will be set.
Light
M.K. Gandhi
  #25
Old 02-19-2004
crazydoc's Avatar
Master Baiter
Quick, where do I go to change?
Do you have a source for that factoid? I'd be interested in seeing how the conclusions were reached.
