Old 02-05-2004
shackrock's Avatar
shackrock shackrock is offline
1K Silver Member
shackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond repute
quiet acoustic guitars
So I double mic my acoustic.
2 mxl603s into DMP2.
It's really pretty noisy. The acoustic guitar part is really quite, finger picked, slow, etc. So it's hard to get a decent level without all this noise. Any tips people have?
Scott Solo
Old 02-05-2004
grinder's Avatar
grinder grinder is offline
Force of Nature
grinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond repute
May seem obvious, but make sure you don't have a pad switched on. How are you positioning the mics?
Old 02-05-2004
c7sus's Avatar
c7sus c7sus is offline
Disenfranchised Member
c7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond repute
The pad might be the problem.
Another problem might be matching gain stages. If you're sending a -10 signal into something expecting +4 that could be the problem.
What soundcard are you using?
Other ideas:
Make your room as quiet as you can. Turn off your reefer and HVAC while tracking. That will lessen line noise when compressors and fans kick in, and ambient noise in your room as well.
You may have to close mic as tight as you can.
Compression might help.............. or might not. Depending on how you use it, and how quiet the guitar is, compression may only raise the level of noise.
The next solution may be higher output mics, and a preamp capable of pumping more CLEAN gain to your medium.
Old 02-06-2004
glynb glynb is offline
Balladeer
glynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond reputeglynb has a reputation beyond repute
You don't say what the noise is? Background noise from the room, in which case the suggestions given should help, or noise from the playing style - eg arm rubbing on the body of the guitar, buzz from frets, squeeks from sliding up the fret board, etc, all of which close micing will pick up even more clearly i guess.
Having said that, a small amount of this type of noise is all part of the 'human' performance IMO.
Online home
Old 02-06-2004
Bob Keelan's Avatar
Bob Keelan Bob Keelan is offline
Senior Member
Bob Keelan has a reputation beyond reputeBob Keelan has a reputation beyond reputeBob Keelan has a reputation beyond reputeBob Keelan has a reputation beyond reputeBob Keelan has a reputation beyond reputeBob Keelan has a reputation beyond reputeBob Keelan has a reputation beyond reputeBob Keelan has a reputation beyond reputeBob Keelan has a reputation beyond reputeBob Keelan has a reputation beyond reputeBob Keelan has a reputation beyond repute
FWIW I have both the 603s and the Oktava MC012s. In general I prefer the 603s on acoustic guitar but kinda lean towards the MC012s for finger picked stuff.
Old 02-06-2004
StevenLindsey StevenLindsey is offline
Force of Nature
StevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond repute
To do quiet acoustic recording with 603s your amp is going to have to be capable of some nice HOT output with NO noise. I'm just now approaching that with a Sytek and and a RNP but I still ain't quiite satisfied. The Sytek will get you almost dead silent in the background with the 603s. Just a thought.
