Old 02-04-2004
wimat wimat is offline
Junior Member
wimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond repute
Anyone have tracksheet template
Just wondering if anyone had a template or something of that nature for a tracksheet. I could probably make one on excel or something, but I'd probably forget key infomation. So maybe, if you don't have a tracksheet, what should I include if I make one. Maybe
-track number
-mic
-placement
-insert
Old 02-04-2004
andyhix's Avatar
andyhix andyhix is offline
www.miterecords.com
andyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond repute
I have a sheet I use with my 424, that basically has a blank outline of the knobs and faders, etc, that you can pencil in levels and whatnot. It helps to get the changes during mixdown perfected, especially if you mixdown, give a listen, then wanna make some minor tweak down the road. I don't think that's what you're talking about, but I'd be happy to share if you or anyone else is interested. It's fairly specific to the 424mkii, though, I think.
Old 02-04-2004
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
I use this...
http://www.massivemastering.com/spec...TrackSheet.pdf
Sometimes a whole session goes on one sheet - Other times one song only. Depends on the session setup.
All the small box areas are for stuff like Background Vox, Horns, SFX, whatever and you can check off what is in what song. Get it?
The box under the track label can have the mic/insert info (I write really small).
Hope that gives you an idea...
John Scrip - www.massivemastering.com
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 02-04-2004
littledog's Avatar
littledog littledog is offline
Three Thousand and Counting
littledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond reputelittledog has a reputation beyond repute
You should make that template on your speadsheet. Yeah, you may forget a useful parameter, but no big deal - just add it in next time. This way you'll get exactly the info you need for your particular setup.
I created one that is used primarily to help me visualize and pre-plan my session setup:
mics
preamps
compressors
snake cable numbers
Pro Tools inputs
Pro Tools Outputs
If I was using tape I'd also want stop and start times.
You may also want a space for writing comments and jotting down problem spots. If you use a lot of outboard hardware, you may also want a place to record parameter settings.
Old 02-07-2004
Real Tones Real Tones is offline
Newbie
Real Tones is on a distinguished road
Here's a straight forward track sheet put together by Micheal Rush; http://www.michaelrush.com/audio/
Old 02-10-2004
SPINSTERWUN's Avatar
SPINSTERWUN SPINSTERWUN is offline
?Como te trata la vida?
Location: spinsta1 does not rest upon "it" an essential condition of the subject, a condition that has been detached from the 'they'; "it" is rather an existentiell modification of the 'they', of the 'they' as an essential existentiale.
SPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond reputeSPINSTERWUN has a reputation beyond repute
Good links.
Peace...
spin
Old 02-10-2004
Emperor !!! Emperor !!! is offline
Junior Member
Emperor !!! is on a distinguished road
sorry
sorry, but I've never filled any track sheets before, so can anyone help me to fill the one I downloaded from michael rush's site???
I like the music to crush the living daylights out of the listener!!!
Old 02-11-2004
Junior Member
Thanks a lot guys, that helps.
Old 02-11-2004
fenix fenix is offline
1K Silver Member
fenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond repute
track sheets are for rookies
Old 02-11-2004
wrenhunter wrenhunter is offline
Junior Member
wrenhunter is on a distinguished road
Post
Hey, we're all rookies. When it comes to love.
Except your sister.
