Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 02-02-2004
royharper3220 royharper3220 is offline
Senior Member
royharper3220 has a reputation beyond reputeroyharper3220 has a reputation beyond reputeroyharper3220 has a reputation beyond reputeroyharper3220 has a reputation beyond reputeroyharper3220 has a reputation beyond reputeroyharper3220 has a reputation beyond reputeroyharper3220 has a reputation beyond reputeroyharper3220 has a reputation beyond reputeroyharper3220 has a reputation beyond reputeroyharper3220 has a reputation beyond reputeroyharper3220 has a reputation beyond repute
groove tubes 1b
does it require phantom power? I thought i read somewhere it was a hybrid and didnt need 48v, but i could very well be wrong.
Any one use this for acoustic guitar, btw?
Old 02-02-2004
Marik's Avatar
Marik Marik is offline
Pro Microphone Design
Marik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond repute
Are you talking about FET or tube version? The FET requires +48 phantom, and the tube comes with its own PSU block.
Old 02-02-2004
Senior Member
o yeah im talkin about the tube version. could explain what a psu block is? im guessing this is not the same thing as a 48v power supply, and you wouldn't turn on the 48v on your pre.
Old 02-02-2004
Marik's Avatar
<o yeah im talkin about the tube version. could explain what a psu block is? im guessing this is not the same thing as a 48v power supply, and you wouldn't turn on the 48v on your pre.>
PSU=power supply. Unlike solid state devices (which FET is) tubes require two voltages to make them work. High voltage-low current (aka B+, or HT--high tension)--this one for anode of the tube, and low voltage-high current for filament (aka heater). The 48V phantom power would not provide these voltages, or current capability. However, I heard about some mics which work with phantom, but most likely these use special tubes (like some tubes designed for portable radios and have low B+, and low current filaments). You don't need to turn your phantom with GT 1b, however it won't damage your mic if it is on.
Old 02-03-2004
Senior Member
learn somethin new everyday on this forum,thanks.
