Old 01-30-2004
Phyl's Avatar
Phyl Phyl is offline
Master of the Obvious
Phyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to behold
Split note to tracks
I have a drum track composed (track #19) and am trying to split the notes to separate tracks using the following sequence:
Process/Run Cal/Split note to track/source track=19/first destination track=20/destination channel=1/destination port=1
SONAR does split the track into 10 new tracks as expected, but it also doubles each note in each track. For instance, for each snare hit note, the note is repeated twice at the same time. I didn't notice this until I deleted a snare hit and found that there was another note hidden directly under the note I deleted.
Any one else had this problem? I'm downloading all the patches available for SONAR 2.0 XL, maybe one of them will fix the problem.
Old 01-30-2004
Phyl's Avatar
Never mind, I figured it out.
Seems the "Split note to Tracks" program has a problem when two adjacent clips overlap each other, even by a slight amount.
