BUG? Can anyone emulate this one?
Greetings and Happy New Years all round!
I think there is a bug with Sonar PE 3.1 relating to the automation of the Sonitus effects when used on a sub-group bus. If I stick any of the Sonitus effects on a track, I am able to arm a parameter for recording, record my interface tweaks and they display the envelope and it plays back correctly when I am done. I used the Sonitus WahWah to test this but all the others do the same thing. But, if I stick any of the Sonitus effects of a sub-group bus, then I can arm the parameter, record the automation and get an envelope displayed but this does not make the interface move or the sound change. If I stick another plugin, (I used iZotope's Trash), onto the same effect bus and re-route the envelope to one of it's parameters then everything responds correctly. Weird. Can anyone emulate this? I have reported it to Cakewalk but am yet to hear anything. I know that the Sonitus Ultrafunk stuff are actually written as VST effects which were internally "wrapped" for DXi compliance with the release of 3.0. Maybe something weird happened in this process? This was a clean install of Sonar 3.0 PE patched with the "B" version of the plugin patch and then updated to 3.1 running on Windows 2000 SP4. Ciao, Q.
<insert something witty here> |
I'm not sure if this will help you, but 3.1.1 update is available now...
http://www.cakewalk.com/support/kb/kb2004199.asp (downloading while typing) FYI, I also found many weird interesting behaviour of Sonar 3 after patch 3.1 installation. All my previous project using Ultrafunk in the any track insert didn't recognize this plugins anymore. I can see the plugin, but still have same popup message "Following plugins is missing...". I reinstall Ultrafunk. The problem is still there... It's gone if I re-insert it. Vsampler is another story. It closes Sonar if I open the VSampler DXi control panel. Hmmm... ![]()
Keep Rockin' and Rollin'...
Installed 3.1.1 and still got the same behaviour.
Anyone else able to emulate this? ?? Q.
Looks like this is just a problem with my install........... Unhappy, Jan.
Can anyone think of any reason why this would work correctly on a track and not on an output bus? Help! Q.
