I tried the SEARCH engine but can't really find a direct answer....
Trying to improve my drum sounds (JV1010) I tried playing a round with soundfonts and Vsampler lately. Through the SEARCH engine I have enough info to let me play around and using Vsampler.... I am using Audiophile2496 and Vsampler as a DXi in Sonar to play soundfont.... Now I am trying to figure out how to convert the soundfont tracks to audio for further processing... it's quite confusing and I can't figure out the best way.... The cakewalk helpfiles suggest that the way to convert DXi tracks to audio is by using "bounce to track"... I tried that with success but find it to be quite troublesome... are there other ways? Soundfonts user with non-SBLive cards, please share how have you been using and recording with soundfont. ![]() Thanks! Leeking |
Re: How to convert soundfont to waves via Vsampler?
I don't see why you should have to Bounce to Tracks before processing. Just smack the effects on VSamplers output track, and you're good to go! ![]()
Two wrongs don't make a right, but two Wrights once made an airplane... |
I'm a bit surprised, moskus didn't show up with this link...
http://home.no.net/magnesiu/cakewalkfaq/vsampler-sf.htm ![]() Anyway, Leeking, you headed right way. "Bounce to tracks" is the way to go. What's your specific problem? ![]() ps. Gong Xi Fat Chai... ![]()
Keep Rockin' and Rollin'...
![]() I actually don;t have a specific problem yet as I am stiill testing the waters with Vsampler and soundfont. Just want to do things the right way.... I did some more playing around and test out some drum sounds with Blue Jay and Golddrum.... sounded good. Looks like I can take that drum machine off my to-buy list. ![]() |
What version of Sonar are you runing, Leeking?
Sonar 3 comes with bunch of samples on the CDs. I haven't checked 'em all, but looks like perfect combination of samples and soundfonts will make drum machine obsolete earlier ![]() ![]() Jaymz
Virtual sampler
I am using Sonar2.
![]() You use Vsampler for the samples as well? (.wav files) is it the same concept as using soundfonts files? |
I use Sonar 3 PE, keep SBLive! to play soundfonts beside Delta 1010LT. I use IK Sampletank came with the 1010LT to play wave sample, thus I rarely use VSampler. I was thinking of using Vsampler3, but then again I had problem running it when I upgrade to Sonar 3.1 patch (for my case I think). Sonar shut down if I open the Vsampler control panel. I send Cakewalk this problem, but looks like I'm not the only one...
Hi james,
I remember seeing in previous threads you said Sonar can record SBLive! Soundfont internally... can you guide me in doing that? I have Audiophile2496 and SBLive! value in my PC. But in Sonar, the only audio inputs I can see is from Audiophile2496. Is there something wrong? The MIDI part of SBLive! in Sonar is working well though.... My sonar is version 2.0 |
I was refering to this thread: http://www.homerecording.com/bbs/sho...t=soundfont%2A
Refering to the pic attached, I dun seem to have a choice to choose "Stereo SBLive! Wave Device"... Is there something wrong with my Sonar-SBLive! configuration? |
BTW,
My setup: Sonar 2.0XL SB Live! Audiophile2496 Win98SE Any problems? ![]() |
#12
Leeking, look at this:
http://home.no.net/magnesiu/cakewalk...soundfonts.htm from this page: http://home.no.net/magnesiu/cakewalkfaq/ ![]()
#13
#14
![]() Quote:
I assumed you use ASIO driver. All you need to do is to switch the driver to either WDM or MME. If you use ASIO driver on Options-->Audio-->Advanced tab. And on Options-->Audio-->General tab you must use 16bit 44.1Khz, because that's the best SBLive! can handle. Run wave profiler and restart Sonar.Quote:
The rest procedure can be found on the link you mentioned above ![]() ![]() Jaymz
#15
Thanks guys...
Hmmm, I am pretty sure I had the "always use MME" box checked.... anyway, will verify tonight when I get home. ![]() will let you know the outcome. ![]() |
#16
great news guys!
after some tweaking and reinstalling last night... finally got everything to work and now I can play AND record soundfonts with my SBLive! ![]() One last question, ![]() Do you always records soundfont in stereo....? Are their samples always in stereo, if not, how to tell them apart? ![]() Thanks mucho! |
#17
![]() Mono/Stereo soundfonts? That's easy! Use your ears! Are they stereo samples? If you don't know, then you can record a tiny bit in mono and hear if the sound is changed dramaticly. If it does, then I'm betting on stereo-samples. ![]()
