Old 01-22-2004
mbouteneff mbouteneff is offline
Senior Member
mbouteneff is a splendid one to beholdmbouteneff is a splendid one to beholdmbouteneff is a splendid one to beholdmbouteneff is a splendid one to beholdmbouteneff is a splendid one to beholdmbouteneff is a splendid one to beholdmbouteneff is a splendid one to behold
Stupid question about ASIO Drivers
Alright, I just purchased an M-Audio Delta 1010LT card as well as Sonar. The soundcard manual talks about enabling ASIO drivers for your software application. At this point, all I know about ASIO is that is stands for Audio Stream Input/Output. Can someone briefly explain to me what the benefit of using them is, and how I can tell if it's desirable to use them instead of the "default setup" in Sonar?
Thanks, much appreciated!
-M
Old 01-22-2004
drstawl's Avatar
drstawl drstawl is offline
5K Californium Member
drstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond repute
Cool
It's supposed to reduce latency in the multitrack environment.
Steinberg developed it and they make some mighty tight SW.
Give it a try! If you have the hardware (and the Software) and the drivers to support it there is no good reason to NOT try it!
Old 01-22-2004
Senior Member
coolio!
Hey, sounds good -- thanks drstawl!
This is my first dive into recording, so I won't have a frame of reference to compare against, but you're right -- Why not? I'll trust Steinberg.
Thanks! (enabling drivers as I type)
...now if I could just figure out how to get the MIDI signal from my DGX202 keyboard to get through...I love this stuff!
Old 01-22-2004
Senior Member
Other driver listed...
Okay, I enabled the ASIO drivers in Sonar. When I did so, other options were also listed:
default
WDM/KS
ASIO
MME (32-bit)
I went with ASIO. Let me know if I should consider the others -- thanks again!
Old 01-23-2004
AlChuck's Avatar
AlChuck AlChuck is offline
Been Here, Posted That
AlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond repute
Check in the Cakewalk forum on this issue. I know that SONAR now supports ASIO drivers but that's a new development, so perhaps their support for WDM drivers is better. It probably also varies on a device-by-device basis -- some products might have more mature ASIO drivers available than WDM, some vice-versa.
Old 01-23-2004
Senior Member
coolio
I'll check - thanks for the advice.
Old 01-25-2004
baba baba is offline
Newbie
baba is on a distinguished road
Hi,
I have and use Sonar Producer 3.1 with kX Project ASIO on an Audigy 2 ZS soundcard.
The advantage of ASIO, for one, it should play back, with effects on ( called live input, input monitoring, etc. ) at very low latency. I have a setting of 5.33 Ms @48000/16 bit. This is nearly realtime and makes something like amp sims ( Revalver ) and other effects respond at a speed that works while keeping time to a click track or drum, as you play your instrument.
The general rule of what works best for low latency is ASIO = very fast, WDM = quite fast ( I can get 10 Ms in Sonar with kX wdm ), and last MME, which I never use.
I use WDM quite often for large projects that don't require 'live input' at 24/96 but my ASIO driver is limited to 16/48. kX Project is developing ASIO 24/96 driver for Audigy 2 cards, so I will probably use ASIO for all programs soon.
cheers,
baba
