Understanding Preamp Gain Structure With Mics
Given: AT4040 has an open circuit sensitivity of -32dB/25.1mV in relation to 1 volt / 1 Pascal.
Amplifying this signal, or raising it +32dB to 0dB produces a 1 volt output. Question: does this mean the preamp must provide 32dB of gain to amplify the mic output to near line level? If so, then the mic sensivity specs are a good indication of the preamp gain requirements. Taking a worse-case example, the Beyer M201 dynamic full-range mic. It is rated at -58dB/1.2mV. Does this mean the preamp must have 60dB of gain to accomodate this mic? What I'm getting at is, if an engineer wants to use Beyer M201 mics, his preamps should be capable of delivering 60dB gain, or it will never produce full output (LINE) level from the preamp. |
Re: Understanding Preamp Gain Structure With Mics
What/Where is PSW?
prosoundweb.com
make it one of your favorites it has lots of great info In HIs Name BK
In His Name Big Kenny |
