Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 05-25-2000
Suntag Suntag is offline
Junior Member
Suntag is on a distinguished road
Unhappy
Hello again, fellow folks of musical inclinations! Quick recap: I'm primarily a singer-songwriter who writes on keys, guitar (acoustic) and now wishes to - e x p a n d - his (my) musical horizons. Hence, bass playing. More specifically, I wish to delve into the jazzy licks of the Upright bass. It's been in my veins forever, but the leap is a steep one.
Problem: Nothing seems to exist under 15Grand.
Question: Is a 2000$ upright even worth purchasing? Or is it the Vantage of classical basses?
Anybody do acoustic bass? (...again, the crickets...)
-Suntag-
Old 08-05-2000
trag-o-caster trag-o-caster is offline
Newbie
trag-o-caster is on a distinguished road
15 grand?!? The most expensive upright that I've found is around $2000 and I actually preferred the $800 one next to it. Try Elderly's Instruments in Lansing, Michigan. They always have a couple of used upright basses there and very reasonably priced. I LOVE acoustic bass and can play them a bit. They're very difficult to play. Huge telephone pole neck with telephone cable strings. What a sound though! Try elderly.com. I think they'll have what you're looking for. Good luck! Trag.
Old 08-08-2000
Col_Forbin Col_Forbin is offline
Senior Member
Col_Forbin is on a distinguished road
Some of the italian basses can range up to $50,000...i'm serious i've seen the prices myself!! even bass bows can range up to $2000....the semi professional ones you can pick up for a couple hundred...me? i gots a Glasser fiberglass French bow that goes for about 35 bucks hee hee...
as far as cheaper basses are concerned, you can get a good student bass for about 1 or 2 grand...but be careful about HOW cheap you go...most student basses are set up poorly and are difficult to play...if this is the case you can get the bridge filed down (don't do it yourself, take it to a professional!!!)...or if you can afford it, get an adjustable bridge put on....
here are 2 ways you can see if the action is set up well...
1. take your pinky and put it between the E string and the fingerboard alllllll the way at the bottom of it...where it sticks out over the body...if your pinky actually fits IN there, the action is too high. file the bridge.
2. the distance between the fingerboard and the strings all the way by the nut should be the width of a playing card...if it's any wider, file down the nut...
if you're buying a bass for like 1 or 2 grand, it will almost definitely be plywood...the carved basses tend to be a SHITLOAD more, and are used more by classical players but are good for jazz too...it's said though that plywood basses have a better pizzicato sound for jazz...an old Kay bass is a pretty standard poor man's upright bass hehehe...
nice sound....or englehardt which is made in the old kay factories....
also the plywood basses respond a little better to humidity changes...in the summer the back of the bass fills up with water and the bass bows foreward, raising the action...once the weather gets cooler and the wood dries out, it pulls the fingerboard back into the strings...with a plywood bass (and an adjustable bridge), there's a little bit less of that....and on that same note, if the air is too dry, it's a good idea to get a pair of dampits...foam rubber tubes that fit in the F holes of the bass (with rubber ends which keep them from falling in hehehe)...fill them with water and squeeze them out first....
hmmmmmmm what else....the strings are important too because if you're going to be playing primarily with your fingers, make sure you don't get classical strings because they will be harder on your fingers...spirocore strings are good, and D'addario makes Helicore Flatwound strings for upright bass...they're like $100 a pack but they should last at least a year if you play regularly including outdoor gigs...
maybe a little more than that.....
ummmmm that's about as much info as i can get at 4 in the morning without looking at a book or something....hope i've helped you out!
-J
Old 08-09-2000
Daddy-O Daddy-O is offline
Senior Member
Daddy-O is on a distinguished road
Cool
For the classic rock-a-billy sound i.e. the Crickets, you need and old American made bass. I would suggest a older Kay, Roth (made by Kay), or an Engleheart. Any of these brands will serve you well for starting out and give you good tone and playability for rockabilly or jazz. These basses are a 3/4 size and range in price from $700 - $2500 depending on age and condition. American basses from the 1940's 50's seem to cost more than some newer ones. Engleheart is still in business and still made good quality basses for the money. If you shop around, you can find Chineese and Korean made uprights for $1000 or under. Three shops in my area sell basses. Both vintage and new.
I can't fing phone numbers at this moment but do a web phone search for: WEST MUSIC, STATESVILLE,NC USA and ANYTHING MUSICAL, CHARLOTTE, NC and MUSIC MAKER, CHARLOTTE, NC. Also check out Bluegrass Magazine, there are many adds for music shops and individals that specialize in violins, fiddles and uprights.
