vf80 to atari sync
hi
i'm currently trying to integrate a fostex vf80 multitrack into my midi setup. my (antiquated) weapons of choice are cubase v2.0 for my upgraded st, & udo weyer's complete cubase manual. and i'm having problems... so far, i've only used the synchronization menu to select "send midiclock: atari" to run loops on old roland kit, and it's all been fine but... the multitrack allows you to select either mtc or midiclock as an external sync, and also offset values. in both modes, with cubase as master and vf80 as slave the following happens: the record channel is armed manually, and i press play on cubase. after the offset time, the vf80 "slave" light stops flashing, becomes solid, and its transport bar runs in sync with cubase. what doesn't happen is that the record light doesn't become solid, and audio is not recorded. in normal manual mode it's a case of press play whilst holding down record to start recording - both lights are then solidly lit and recording starts. cubase doesn't seem to be sending it's play/start signal to do this. if multitrack is armed and waiting for clk/mtc start signal to start recording (i'm following same procedures for manual record arming) and i can see it lock to sequencer and the clock start running following relevant offsets(mtc time/bar value) how can i actually make it record! if anyone can take me throught the necessary settings in the sync menu i'd be very grateful. someone in another forum suggested to chechk what cubase 2.0 has in terms of "chase lock" and it's "start/stop" functionality. i can only find "chase event" and am not really sure what there is to "start/stop" beyond the obvious. the vf80 starts & stops with cubase - it just doesn't start recording! thanks gavin |
