looking for limiter and compressor under 200 that is clean
recommendations?
i will search for reviews
"Just like Music" |
The RNC by FMR.
http://mercenaryaudio.com/realniccom.html |
You need a clean limiter for under $200?
Good luck. BTW: I know of a plugin limiter that is relatively clean that can be had in that price range: http://www.sonictimeworks.com/p_masteringcomp.php |
The two functions at the same time? Hardware?
The RNC can be very fast OR all the slower stuff and very clean.
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini (formerly S.P. Technology |
i got that plugin and a million more (don't ask don't tell)
however i was looking for decent outboard equip
"Just like Music" |
As a general rule, you can find a lot of good, clean compressors out there in that price bracket -- notably the RNC, which has already been mentioned.
But as far as limiters go, it's highly unlikely you'll find anything out there outboard that's even close to transparent untill you get in to something like the Safe Sound Audio, which is supposedly very transparent -- but it comes in at around 500 bucks and includes a really good, clean comp and mic pre, though, to boot. You could look around on ebay for a used Aphex dominator, but that would probably set you back $200 or so all by itself. Right now, your best bet is to be sure to track at 24 bit, use an RNC and just leave enough room for possible overs -- then do any limiting you might want to do with software. |
Look into the Behringer Composer 2100...its a Compressor/Limiter/Gate...it will be cheap...and it wont be a distressor or anything...but it should do you the job...
