Old 01-02-2004
gtrplayer_1966 gtrplayer_1966 is offline
Newbie
gtrplayer_1966 is on a distinguished road
Best way to get from VF80 to Computer
Using the VF80. After composing and getting everything set (effects and channel levels etc.) I then simply go out of the VF80 via the two stereo outs into one stereo jack into the computer's line-in on the soundcard.
The soundcard is what came with the computer which is a Gateway and was purchased in 1999.
I then play my recorded music while recording it with software such as Sound Forge or whatever I happen to find that works simple enough. Then "normalize" it, then I use another program to take it from .wav to .mp3 for emailing and burning.
The files sound "ok" but, a lot of times the bass is way too over the top, and other times it will sound thin or muffled. There is also a "hiss" that I can't seem to get rid of.
I "EQ" it and add effect within the VF 80 of course prior to sending to computer.
Is there some good simple bettter software that I can use?
should I upgrade the soundcard?
Should I upgrade the computer AND the soundcard?
Am I, in fact, sending it to the computer in the right way?
Please advise.
Thank you for your time,
Matt
If you hit a wrong note...KEEP GOING!
Old 01-02-2004
Kramer's Avatar
Kramer Kramer is offline
R.I.P Dafduc
Kramer has a reputation beyond reputeKramer has a reputation beyond reputeKramer has a reputation beyond reputeKramer has a reputation beyond reputeKramer has a reputation beyond reputeKramer has a reputation beyond reputeKramer has a reputation beyond reputeKramer has a reputation beyond reputeKramer has a reputation beyond reputeKramer has a reputation beyond reputeKramer has a reputation beyond repute
The best way for the best quality is using the Fostex CD-1A CD-R/RW burner.The VF 80 already has an an internal bay thats just waiting for you to install it.
Once you get it burned onto the CD you can then put the CD in your CD-ROM drive on the computer and go from there.
Another way to transfer to puter is to utilize the VF 80's SPDIF In/Out by upgrading your soundcard to something like a Terratec that has SPDIF Input/Outputs on it.
Old 01-02-2004
Newbie
Thank you,
I am aware of the built in CD Writer etc... I had it, and then returned it. For the price it is easier to just go directly into the computer.
So Instead of the stereo outs into the computer us the SPDIF outs to an upgraded soundcard???
thanks again
matt
Old 01-02-2004
Kramer's Avatar
R.I.P Dafduc
Originally posted by gtrplayer_1966
Thank you,
thanks again
matt
The way you are currently going into your computer is defeating the whole purpose of staying inthe "digital" realm.You are going "analog" as soon as you go into your computer souncards normal input.
Thats why the burner is preferred if you are truly concerned with sound quality and staying in the digital realm.The SPDIF will allow you to stay in the digital realm also as I mentioned.
I would have kept the burner but thats me.CD's are a cheap even if you do just get one song at a time onto CD.It ultimatlely comes down to sound quality.
Old 01-02-2004
Newbie
AHHHHHhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh!!! I C Clearly now Watson!
You have cleared MANY MANY questions up for me my friend!
Thank you so much! Hmmmm....Hence the bad quality in the computer!
Ok...so I'm now in the market for a nice sound card. I'm hearing a lot of good things about the Delta on that's on musiciansfriend for 99bucks. reg like 249 or something.
Thanks for the input!
Matt
Old 01-04-2004
Tubedriver Tubedriver is offline
Junior Member
Tubedriver is on a distinguished road
Thank you,
thanks again
matt
man you are SO wrong here, the CDRW will allow you to burn all your tracks (yes...all 24 of them) as .wav files onto a CD. You then load that up into your PC and simply import them into your mixing program.
You can then do all your mixing and effects to the tracks in your PC which is a much easier process IMO than on the vf80.
You can also archive all of your tracks and songs onto CD in one pass. Try doing that track by track - song by song into the SPDIF port of a PC....you'll go nuts!
And if all you want to do is record your stereo mix downs into a PC, you are still better off burning them as 2 wav files onto a CD and transferring it to the PC.
I would not have a vf80 unless it had the CDRW built in!
Tube
Old 01-05-2004
Newbie
What do you use to add effects and edit your tracks on the computer?
I have Cakewalk now. Is that good?
Old 01-05-2004
Junior Member
yeah, Cakewalk is fine. I'm using ACID Pro at the moment which is a nice program.
Old 01-15-2004
jonathanz jonathanz is offline
Newbie
jonathanz is on a distinguished road
yep yep yep...
I think tube is right you can just transfer on cd and if your willing to upgrade card and computer why not go the burner route and then you just run straight to disk not analog back to digital. That's like the one legged man in that wonderful contest!
the man the myth the legend!
