Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 01-01-2004
whattaguy whattaguy is offline
Force of Nature
whattaguy has a reputation beyond reputewhattaguy has a reputation beyond reputewhattaguy has a reputation beyond reputewhattaguy has a reputation beyond reputewhattaguy has a reputation beyond reputewhattaguy has a reputation beyond reputewhattaguy has a reputation beyond reputewhattaguy has a reputation beyond reputewhattaguy has a reputation beyond reputewhattaguy has a reputation beyond reputewhattaguy has a reputation beyond repute
What happened?
I purchased an AT 4040 a little over a month ago, and it worked great the first time I used it. Since then I've been busy and finally got a chance to track today. All I got was a loud background hiss, and the mic signal was very weak if there was any signal. I tried other cables, and that didn't help. Other mics worked with the same cables. Does anyone have a clue as to what happened? I'll try to see what GC could do for me. Thanks.
Old 01-01-2004
joro's Avatar
joro joro is offline
I like pie.......and cake
Location: Clowns to the left of me...Jokers to the right....Here I am....
joro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond repute
ummm...are you running it through a pre with phantom power?
Old 01-01-2004
Force of Nature
Oops...my bad. I'm running it through my Aardvark DP 2496 pre's with phantom power. The other mics that I was testing were condensors also. I'm thinking my mic "went bad" if that's possible.
Old 01-01-2004
Force of Nature
Anyone?
Old 01-01-2004
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
If other mics work with the same signal path as you try for this one, then it does point to a mic failure.
It is possible that you blew the internal circuit on the mic if you didn't power off the phantom power before you disconnected the mic cable from it, or it simply is a defective unit. Either way, you'll have to take it back to the point of purchase for service........ if you killed it by mishandling phantom, you'll likely be charged for it, otherwise, it should be covered under warranty if you bought it new....
Old 01-01-2004
Force of Nature
Ugh...but thanks!
Old 01-03-2004
Force of Nature
So here's the deal:
I went to GC today, and said that they would honor an exchange, but they wanted to test to see if the mic was actually defective. As it turned out, it worked on they're system, and wouldn't exchange it implying that I was some idiot trying to rip them off. I thought that if it worked perfectly at the store, I'd have no problem taking it back home. Well, I tried it again, and it still didn't work! My V57 and MK012's work fine with the same cable and channel. What else is going on? Am I missing something? This kinda sucks.
Old 01-03-2004
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
If GC won't help you out, I'd call Audio Technica and see if they have any possible insight in to this.
Maybe it just doesn't like your aardvark. Did you try it through any other mic pres? It's possible that it needs more phantom power than your other mics do, and perhaps your card's pres aren't delivering it?
Old 01-03-2004
Flatpicker Flatpicker is offline
Flatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond repute
Do you have a voltmeter? If not, pick up a cheap one at Radio Shack, Sears, Lowes, or Home Depot (you need one in your studio anyway!) and do this:
Plug the V57 into one channel. This is needed to “load” the phantom power voltage. Plug another cable into one of the other channels. The connecter on the other end of this cable is where you’ll take the measurements. Turn the gain all the way down and make sure the phantom power is OFF. Set your voltmeter to “DC volts” and set the range to the next step above 50 volts. Stick one of the probes into pin 2 and the other into pin 1. Pin 3 is in the middle, so 2 and 1 are at opposite sides of the connecter. Don’t worry about polarity as it doesn’t matter. If the probes are backwards, the voltage will just read negative instead of positive – no big deal. Turn the phantom power ON and you should read 48 volts. If you read less than 40V, the Aardvark isn’t supplying enough voltage and may be defective. Incidentally, my Aardvark Q10 supplies 48 volts no matter how many mics are plugged in.
For curiosity’s sake, I’d try the same process with the 4040 instead of the V57. Whether the voltage stays at 48V or drops using the 4040, this information would be good to have when you call AT to explain the problem.
Old 01-03-2004
Force of Nature
I'm getting 10.31V on the reading on all mics...what do I do now?
Old 01-03-2004
10.31 is kinda low.... sounds like the problem may be in the phantom power suuplied by the Aardvark........
  #12
Old 01-03-2004
Force of Nature
Would my computer power-supply have anything to do with it? My supply is 330W and is a couple of years old.
My PC rig is:
ASUS P4T533C Mobo
P4 2.4 Intel chip
1 meg RAM
40G Seagate 7200
60G Maxtor 7200
Plextor CDRW
Pioneer DVD Rom
Soundblaster
Floppy Drive
GeForce 3 Ti200 AGP Graphics card
2 case fans
1 cpu fan
The Aardvark gets its "juice" from the computer...it's not independently powered.
  #13
Old 01-03-2004
Sonixx's Avatar
Sonixx Sonixx is offline
1K Silver Member
Sonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond reputeSonixx has a reputation beyond repute
what's the voltage with no mics (nothing) plugged into the Aardvark?
  #14
Old 01-03-2004
Force of Nature
10.36V
  #15
Old 01-03-2004
The Aardvark's defective. Contact them and describe the problem. BTW, when it's fixed, your other mics will sound much better.
  #16
Old 01-03-2004
Force of Nature
Flatpicker,
Do you have any info on the warranty of the Aardvark units? I bought mine in February '02. Thanks.
  #17
Old 01-03-2004
Flatpicker,
I dug through all my stuff, but I can't find anything except the maunal and it doesn't mention a warranty. Send them an email now and give them a call Monday. As far as you know, it left the factory screwed up and you're just now learning about it. Let me know how it turns out.
  #18
Old 01-03-2004
tom18222 tom18222 is offline
yes
tom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond repute
it could be the computer, if its old, because it gets the power from the computer right?
  #19
Old 01-03-2004
It sure is a posibility. I'd still call Aardvark, though. They may be like... "GULP! There's that same problem again! Yeah, we know what it is - send it back!" On the other hand, if they say "Never heard of it. Check your computer", then I'd try it on another computer before sending it to them.
  #20
Old 01-04-2004
Force of Nature
Flatpicker,
You didn't have to go through that much trouble! Thanks a bunch. I already sent them an e-mail and will try to follow up on Monday.
You guys always pull through for my "off" questions.
  #21
Old 01-07-2004
Force of Nature
I talked to the Aardvark tech, and said that the power supply was a possibility. I just swapped my old Enermax 330W with a Thermaltake 480W tonight to see if that was the problem (was going to upgrade the power supply regardless). I still got about 10.3V on the meter. The good thing is that the tech said that if the power supply didn't fix the problem, they will when I send it back to them. I'll keep you guys posted.
  #22
Old 01-08-2004
Is it still under warranty or are they going to charge you?
  #23
Old 01-08-2004
Force of Nature
Dunno, he just said to send it back, and they'll take care of it. I'm going to call them in a couple of hours.
  #24
Old 01-08-2004
Force of Nature
It's covered, but I'll have about a month downtime (UPS takes a week to get to Ann Arbor, MI). Oh well. I suppose it's worth the wait.
  #25
Old 01-08-2004
Ah, well, just hope it doesn't take them as long as US Cell has kept my defective cell phone!
At least it's covered by the warranty.
