Old 12-30-2003
Cratinus Cratinus is offline
Senior Member
Cratinus is on a distinguished road
best STEREO spring reverbs??
i've been scouring eBay for such an animal. i've seen the following (which i find quite interesting):
Fostex 3180
Furman RV-2
Master Room Stereo reverb (forget the model,..XL-305????)
Orban stereo reverb (111-B,.i think?)
i have an "all-analog" project i'm working on (via my beloved Tascam 246). i'm also utilizing Yamaha analog delays and Ibanez "UE"series analog multi-effects . i'm "trying" to keep the entire project ANALOG (until "CD rendering") and wish to use the stereo spring 'verb on the final mix/bus. any opinions on the above (mentioned) units? if there is a MONO spring 'verb (that is superior) i might consider picking up TWO for my purposes. thanks.
Old 12-30-2003
The Ghost of FM's Avatar
The Ghost of FM The Ghost of FM is offline
French Mofo
The Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond repute
My first Spring reverb unit was a Bi-amp stereo model that sounded really nice on guitar and on vocals. I used to use that when I got my first TASCAM 244 Portastudio back in the early 80's.
Drums sound horrible through any spring unit I have ever heard so I wouldn't recommend you use it for anything percussive in nature.
As for the models you mentioned above, I don't have any direct experience with them but the Orban might be the best of the bunch in that they did used to make some very solid gear back in the day so, I would guess that their reverb unit followed the same traditions as their eq's and compressors of being well built and clean in terms of self noise and distortion.
Cheers!
Old 12-31-2003
Beltrom Beltrom is offline
Dedicated Member
Beltrom is on a distinguished road
Great British Spring had a good name over here - if you haven't seen that name you might want to check it out. I've got an Accessit SRC myself, good reverb (several springs in an external box) but a tiny bit to noisy for me to recommend it.
Old 12-31-2003
Herm's Avatar
Herm Herm is offline
1K Silver Member
Herm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond repute
I dont know about the others but I kinda like my 3180 fostex.
Old 12-31-2003
Senior Member
thanks for the responses, gang. it seems that the Fostex 3180 might be the most affordable unit of the bunch. i might give it a try. the other units have some built in eq and limiting but i can ALWAYS run it (the Fostex) through my old Mackie and tweak the eq as needed (and patch in a compressor if necessary). cheers.
Old 01-02-2004
skullfisher skullfisher is offline
Newbie
skullfisher is on a distinguished road
the best spring reverb you can buy new, IMHO, is the james demeter 'real reverb.' its a real analog spring reverb in a 1u rackmount space. sound is hi-fi!
just make sure you're far from any emf fields, otherwise it will get noisy. very sensitive in that regard.
