(mr8)stereo wav file
When I tried to convert a song I just made to a stereo wav file, it said out of capacity. What gives??
stereo wav file
Your problem might be that there is not enough time left on your cf card to mix those to 7/8. Go to Song menu and use the Delete Unused option. If you did multiple takes on some tracks the time you used up on those old takes can given back. If Delete Unused doesn't give you enough time, then you may need a cf with more memory or transfer your tracks to pc via Fostex wav manager or do a live mix to pc through your sound card and create a wav that way. There is some relatively cheap pc mixing software out there that are pretty versatile which would allow you to exceed the 8 tracks without bouncing, lots of effects etc... n tracks and Power tracks are a couple mentioned here in the forum. Keep reading around. Lots of info in here. Good luck
Thank you very much! The delete unused option worked. The song was a christmas present to my girlfriend. :-) Thanks again.
