Old 12-19-2003
filmdude11 filmdude11 is offline
Newbie
filmdude11 can only hope to improve
Demagnetizer and Tape Head Cleaner for 414MKII?
Could someone recommend a site where I can get a good cassette tape degausser for my Tascam? I guess I'll use it every time I change tapes?? It that right? And what about a tape head cleaner? Do I use that just as often, and if so, before or after the degausser. I think I'll just get a head cleaner at Target or something. I'm pretty sure they won't have degaussers.
One more thing, I've heard TDK is good, and High Bias. Does that sound good.
Thanks,
Corey
Old 12-19-2003
The Ghost of FM's Avatar
The Ghost of FM The Ghost of FM is offline
French Mofo
The Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond repute
Corey,
Demagnetizing should be preformed after aprox. 30 hours of tracking.
I would recommend against the cassette type demagnetizer as they don't do an effective job of covering all the metal parts within the tape path and only address the sync head.
You would be better to buy a wand type demagnetizer as it can be applied to all the metal parts in the tapes path.
These devices are a little tricky to use for the first time user and even some experienced users who are distracted while doing the procedure.
Both Teac and Hand-dmag make good products for this application and come with full instructions that should be followed to the letter for correct usage.
Some proponents of de-magging, would suggest that there is never a need to de-mag and will testify on a bible that their machines are perfectly fine, having never used one.
I use one as a precautionary measure to ensure continued good performance from all my analog recorders.
As for cleaning the heads, Q-Tips and isopropyl alcohol are all that is required for this job. Just make sure the alcohol is 91% pure or higher as the higher the alcohol content, the less the water content and you don't want too much water around your heads!
As for TDK tape; I have had good results with their products in the past offering a good consistency of oxide coating and long life for archiving purposes.
Cheers!
Old 12-19-2003
Newbie
Great. Thanks alot!
Corey
Old 12-19-2003
Newbie
Well, I bought the Tascam E3 from zzsounds.com
Thanks
Corey
Old 12-19-2003
French Mofo
Your welcome!
Don't forget to read the manual for the E-3 when you get it and follow it's instructions to the letter!
Cheers!
