Go Back   Home Recording > User Forums by Brand > Roland, Boss, VS Series Forum
Reply    Audiofanzine Roland boss Roland boss News Roland boss Medias Roland boss Tests Roland boss Articles Roland boss User Reviews Roland boss Classifieds Ads
Old 12-19-2003
warpigs warpigs is offline
Newbie
warpigs is on a distinguished road
Red face Power Supply for an M240 Line Mixer
Anyone know where I can find one??
My brother picked up this mixer a few weeks ago, but with no power supply, so it's kind of useless without it. He said he called Roland, and they couldn't help him.
thanks!
Old 12-19-2003
Newbie
Or anyone who has this mixer...
What's the part number for the power supply??
He said the input says 21.5V and 500mA
Thanks.
Old 12-19-2003
Newbie
Called Roland myself
Got a part number:
ACC-120
of course it's old, so who the hell would have something like that???
Old 12-22-2003
Yasoo Yasoo is offline
Senior Member
Yasoo is on a distinguished road
warpigs -
I just went through a power supply shuffle. I lost the power supply to a Fatar midi keyboard. All it says by the hole on the unit it "DC IN 9V". Gee thanks guys, no mA, no polarity, and Fatar didn't return 2 emails I sent them.
Here's what I found after talking with my dad who is an Electrical Engineer:
You can use any power supply so log as it matches the numbers. So in your case, try to get a hold of a 21.5V 500mA power supply. You can use one that has more mA (eg. 21.5V 750mA), but if it shows less mA, you probably will overheat the power supply and it will stop working because it can't produce enough current. Also, you need to make sure the tip that plugs into your device matches the +/-. So, the tip may be - at the center and + at the outer or vica versa. So you have to make sure that matches. ALSO (who'da thought there'd be so much involved in getting a power supply :0 ) you need to make sure the hole in the tip is the right size. I've seen them 2 different sizes.
Using that info, if you just can't find a match of all those parameters, get the voltage and mA rating as close as possible. If the tip doesn't match the +/-, you can cut the cord, strip the 2 wires, and cross connect them (this will switch the tip from + to - or vica versa). If the hole isn' the right size, buy a cheap power supply for the right tip and cut it off and connect it to the one with the right voltage and amps.
Old 12-23-2003
Newbie
Angry BALLS
I was afraid i was going to have to do something like that...
The hole in the mixer isn't a typical AC/DC converter hole, it's more like the hole on the back of a PC or something.
That's how my brother described it to me.
they have generic AC converters from radio shack for like $25 that can handle up to 750mA or whatever, but the plug isn't the right shape.
so i guess i'll have to carry this thing with me to some different stores and try out any plug that comes close
music123.com says they are on a 2 to 3 week wait from the manufacturer, but seein as how Roland doesn't make them anymore... looks like I'm SOL...
