Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 04-05-2000
nafai nafai is offline
Newbie
nafai is on a distinguished road
Question
OK MIDI Gurus,
I have been trying some experiments with MIDI fading: fading the velocity and volume of patches and tracks both (using Digital Orchestrator Pro and Cakewalk).
Here's the prob: If I fade out a part on my synth, like a drum part, it gradually fades out the way you would expect, without sounding awkward at all. But, when I try the same technique on the Alesis SR-16, the fade is more obvious and does not really fade away at the end. There is a noticable cut off, you can tell when the drum part stops.
Now, I thought it may be because of the fixed velocity setting on the SR-16, but I monkeyed with it a bit and it still reacted the same.
So I figure either: A) The SR-16 can't do what I'm trying to do, or B) I shouldn't be trying to do it this way anyway.
I know I could get the same result I want by recording the drum part for that section as a wav and fading the wav, but since I got the effect to work with the K2000, I want to get it to work with the Alesis. (Of course, I guess it could be a fluke that it works with the K2k...)
Cheers and Thanks!
Old 04-16-2000
reve reve is offline
Newbie
reve is on a distinguished road
Wink
Probably C) All of the above. There's no hard and fast rules for the implementation of MIDI volume messages -- thus on some synths there'll be a dramatic change between 1 and 0, and on some it's a perfect taper. "Response curves" will also vary dramatically.
This is why mixers continue to sell rather well.
