Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 03-21-2000
nafai nafai is offline
Newbie
nafai is on a distinguished road
Question
OK, this is kinda weird:
Last night, while messing with some older sequences, I discovered an oddity. On some sequences, sending program change requests worked like normal, but on some files, program change requests only affected the current channel on my synth (Kurzweil K2000). On those sequences, the current channel on the synth plays the most recent prog change request, regardless of which channel it was supposedly sent to.
Now, you may be thinking "What sequencer are you using, that's probably the problem." Well, I tried it with Voyetra Digital Orchestrator Pro and Cakewalk Pro 9 and the same thing happened in both programs. I also checked the MIDI events list, and there's nothing there related to a program change.
Now, here's the weirdest part of all: I tried on of the problem sequences this morning, and it worked fine.
There are only a couple of things I can think of that could be the problem, assuming it happens again:
1) The file is a standard MIDI type 0 file and should be changed to the standard for the individual sequencer. (Haven't tried this yet.)
2) The file is should be changed to a MIDI type 1 file. (I don't think this would have any effect really.)
3) It's somehow caused by the new memory I added last night. (Possibly, but it seems a bit odd.)
Anywho, if anybody has seen anything like this before, I'd appreciate any more ideas in case it happens again.
Nafai
Old 03-21-2000
Professa Plum Professa Plum is offline
Newbie
Professa Plum is on a distinguished road
Wink
From what I know of computers and MIDI equipment, its just the computer...If everything works fine in the morning, then I say be glad it works now. Computers like to screw up like that every now and then...Just do something completely weird and random, and then when you turn it back on it's fixed...Like the time my computer didn't recognize my hard drive. couldn't figure out what to do, turned it off, turned it back on, and then all of a sudden it was there again...Don't stress about it
Old 03-23-2000
Newbie
Wink
I figured it out. The problem was caused by the demo for MIDI quest 7. I decided to give an ed\lib. program a try, and somehow during the setup of that demo, it switched the local control settings (and some other stuff) on my synth. It took a bit of looking around to find that, but I switched back to defaults and everything is fine again.
