Go Back   Home Recording > User Forums by Brand > Roland, Boss, VS Series Forum
Reply    Audiofanzine Roland boss Roland boss News Roland boss Medias Roland boss Tests Roland boss Articles Roland boss User Reviews Roland boss Classifieds Ads
Old 12-14-2003
JohnnyMan's Avatar
JohnnyMan JohnnyMan is offline
Dedicated Member
JohnnyMan is on a distinguished road
Unhappy How do you transfer files from the VS880 to Cakewalk?
I am losing my mind.
I have tried every setting in the manual and I can't get the VS880 to accept MTC from Cakewalk.
I believe I have all the parameters set correctly, I push play on the VS880 and it waits for MTC. I push record on Cakewalk and the VS880's MIDI/DISK light starts flashing but the time display does not increment. The play light just flashes waiting for something. WHAT??? Please, I would be very grateful for any help getting this to work.
John
Rock 'n Roll Is Just Rock 'n Roll, Yeah!
Old 12-17-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Usually you setup the playing deck as the time code master. Set the Roland to master and the computer to slave.
Old 12-22-2003
Jim Y Jim Y is offline
Force of Nature
Jim Y has a brilliant futureJim Y has a brilliant futureJim Y has a brilliant futureJim Y has a brilliant futureJim Y has a brilliant futureJim Y has a brilliant futureJim Y has a brilliant futureJim Y has a brilliant futureJim Y has a brilliant futureJim Y has a brilliant futureJim Y has a brilliant future
I don't think any Cakewalk below Sonar 3 can transmit MTC. Midi clock yes, but not MTC.
As TexRoadkill says, it should work the other way around.
What version Cakewalk do you have and are you using an s/pdif soundcard?
As one door closes, another one slams in my face.
Old 12-27-2003
xfile xfile is offline
Newbie
xfile is on a distinguished road
Sorry to jump in on the question, but I am also having a similar problem. I have Cakewalk Home Studio 9. Also a roland 840. My question is...How do I set my computer, or cakewalk to SLAVE.
Old 12-27-2003
monty's Avatar
monty monty is offline
Banned
monty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond reputemonty has a reputation beyond repute
http://www.homerecording.com/bbs/sho...hreadid=106026
Old 01-01-2004
JohnnyMan's Avatar
Dedicated Member
Thanks for the reply Jim. I am using s/pdif as the digital transfer pipe. And I am using midi as the sync clock but when I start Cakewalk the midi light flashes on the VS880 but does not start the song.
I have tried it both ways slave/master master/slave but to no avail.
I was using Cakewalk 9.0. I just upgraded to Sonar but haven't tried it yet with the VS880.
John
Old 01-01-2004
JohnnyMan's Avatar
Dedicated Member
Thanks Monty but I couldn't get it to work, hence this thread.
John
Old 01-07-2004
Force of Nature
Well ok, I have Sonar and I can sync it a VS no problem.
VS set to transmit MTC at 30fps. You probably should also have a transport MMC option to set as master.
Sonar Project options/clock - smpte/MTC 30fps
Audio Options/ Advanced / Synchronization - Trigger and Freewheel.
This is why I asked about s/pdif, assuming you have to set your soundcard to use the external audio clock in order to use the s/pdif input, Trigger and Freewheel means Sonar doesn't have to try to hard-sync to the MTC code because the incoming s/pdif from the VS acts as a sync signal by itself. The VS MTC only needs to position the Sonar transport.
A finishing touch is...
Sonar/ Transport/ Loop and Auto Shuttle
Check "Stop at end time" and "loop continuously". If I remember rightly, this stops you having to manually restart Sonars sync between each pass. Sonar should follow the VS transport buttons like a good puppy.
I have no idea why so many related settings are in different places.
My VS is a humble 840EX, and we've found that we don't have to record tracks across to pc, but can use a program for the Boss BR8 to directly turn VS tracks to .wav.
I don't think that will work with the 880, but if you've used the uncompressed recording mode and have a scsi drive to move songs to pc, the "take" files can easily be turned into .wav if you have a good wave editor and can "open as" Motorola 16bit 44.1Khz and then "save as" Microsoft pcm .wav.
Old 01-09-2004
volltreffer's Avatar
volltreffer volltreffer is offline
Imply depressed
volltreffer is on a distinguished road
Cool
You might have selected the wrong digital in - I have a vs880 ex and that sometimes happened. If I recall it right, the recorder will not 'move' then...
aXel
Old 01-12-2004
JohnnyMan's Avatar
Dedicated Member
Thanks for the reply. What do you mean by the wrong digital in?
John
Old 01-12-2004
JohnnyMan's Avatar
Dedicated Member
Thank you very much for the help. I look forward to giving it a try.
I'll let you know either way.
John
  #12
Old 01-25-2004
JohnnyMan's Avatar
Dedicated Member
Talking
Jim Y,
Thank you very much for the help. Your suggestions worked and I was able to successfully transfer my tracks from the VS880 to Sonar. I’m still not sure why Cakewalk 9 wouldn’t let me do it.
Regards,
John
  #13
Old 01-25-2004
Force of Nature
Nice!
  #14
Old 02-02-2004
duck's Avatar
duck duck is offline
Dedicated Member
duck is on a distinguished road
I know it works with 9.3.
Vs880 as slave:
Cakewalk settings:
Under the SETTINGS menu, choose CLOCK and select SMPTE/MTC. Click on OK.
Under the SETTINGS menu, choose MIDI OUT and enable Transmit MMC.
From the same screen, set the Timecode Master's Unit ID to 17. Click on OK.
Under the SETTINGS menu, choose Time Format and select 30 Frame Non-Drop. Click on
OK.
VS-880 Settings:
Press SYSTEM (under EDIT CONDITION) until the display reads "SYS Sync/Tempo ?"
Press YES/ENTER.
Use the TIME/VALUE dial to select Source = ext (Note: if I set this to INT it dosnt work why I have no Idea
Press PARAMETER>> until "SYS Syn:Gen. =" is displayed.
Use the TIME/VALUE dial to select Syn:Gen.= MTC.
Press PARAMETER>> until "Syn:MTC Type =" is displayed. Use the TIME/VALUE dial to
select 30.
Press SYSTEM until the display reads "SYS MIDI PRM ?"
Press YES/ENTER.
Use the TIME/VALUE dial to select Device ID = 17 (if it is not already selected).
Press PARAMETER>> and use the TIME/VALUE dial to select MIDI Thr = Out.
Press PARAMETER>> and use the TIME/VALUE dial to select SysEx.RX = On.
Press PARAMETER>> and use the TIME/VALUE dial to select MMC = Slave.
Click on the play icon in Cakewalk. The VS-880 will begin playback in sync with
Cakewalk.
For the VS-880 to be the master device, use the following settings.
Cakewalk Settings:
Under the SETTINGS menu, choose CLOCK and select MIDI Sync.
VS-880 Settings:
Press SYSTEM until "SYS Sync/Tempo ?" is displayed. Press YES/ENTER.
Use the TIME/VALUE dial to select Source = EXT (if it is not already selected).
Press PARAMETER>> until "Syn:Gen. =" is displayed. Use the TIME/VALUE dial to select
MIDIclk.
Press SYSTEM until "SYS MIDI PRM ?" is displayed. Press YES/ENTER.
Press PARAMETER>> until "MIDI Thr =" is displayed. Use the TIME/VALUE dial to select
Out (if it is not already selected).
Click on the play icon in Cakewalk (it will start flashing). Press PLAY on the VS-880
and Cakewalk will begin playback in sync with the VS-880.
What!
  #15
Old 02-27-2004
JohnnyMan's Avatar
Dedicated Member
Thanks Duck. I can't remeber tonight exactly what my settings were but I am quite certain the problem was in the VS880. When I started playing the song in Cakewalk the midi light would flash on the VS880 but the song would never start.
  #16
Old 03-01-2004
Newbie
840
How bout an 840
O.K. but how about using a V.S. 840
Heres my options
Roland: Midi- device I.D. (1-32) im set at 17
MMC Master- slave- or Off
Thats it in the Midi Settings
Sync Tempo Gen.- Off, MTC, Midi Clock, or Sync Track
MTC type24, 25, 29 ,30
Offset )
Tempo ) Says [enter here]
Sync record )
Those are the only midi related options on the 840
Cakewalk home studio 9:
Options_Project_ Midi out_- Send Midi Sync-
Transmit Midi start/ stop/ continue/clock_ if this is checked then I can also select
Use start never continue
Transmit midi song position pointer
Locate delay for SPP 0- >300
Midi Output port
Those are about my only options, Nothing for Master Slave, Nothing for Device I.D. I Think I just about give up. Any Ideas?
Thanx
  #17
Old 03-05-2004
Force of Nature
The trouble with the 840 is that it can only be a sync master. Double trouble is that Home Studio cannot be sync slave and even then it can only be a Master for Midi Clock, which is only good for hardware midi sequencers, drum machines and synth arppegiators. You need MTC sync for audio. You would have to upgrade to Sonar to get it working (unless the latest Home Studio can slave to MTC, but I don't think so).
Do a search. or read through some recent posts (it's a very common question) in the 840 forum at...
http://www.vsplanet.com/cgi-bin/ubb/ultimatebb.cgi
