Hi,
I try to record at max quality , 96khz sampling rate and 24 bits. I get this message: "The default audio format is not compatible with one or more soundcard" I have an Echo Mia soundcard and I disabled the drivers of my onboard soundcard in Options-Audio-Drivers. what do I do wrong or do I do not? :/ Regards, Thierry |
Have you set the Echo Control Panel (I'm sure it exsists) to 24 bit/96 kHz?
Two wrongs don't make a right, but two Wrights once made an airplane... |
Thanks Moskus,
It worked, I also followed the steps in the read me file of the echo mia card, and in USING SONAR section it said this: "We recommend that you try using Super Channel mode in combination with SONAR; using Super Channel mode can make SONAR more efficient." What is Super Channel mode? Regards, Thierry |
"Super Channel"-mode is not a function in Sonar (as I'm aware of), but maybe you should check your MIA card.
