Old 12-05-2003
Rags Rags is offline
Newbie
Rags is on a distinguished road
Of all the computer programs to record with....
Which one is the BEST, which helps clean the vocals the best, just simply put the all around best...I've been using Cool Edit for a few years, I've recorded rap music aswell as rock music, and occasionally I'm happy with the sound but quite often the quality is kinda not too good....
I use a apex 430 condenser mic, with a art tube mp preamp and a top of the line sound blaster sound card.
I'm not very good at mixing and mastering but I guess i can save those questions for the other forum once i figure out which program to use...
Below are two songs i used w/ cool edit
http://www.ragsmusic.com/Taylor%20Ca...-%20Asshole%20(Beck%20Cover).mp3 <-- rock song
http://www.ragsmusic.com/Rags-NoChance.mp3 <-- rap song
i feel the quality isn't that great and my vocals are not normally the best they could be quality wise (skill wise too...)...but anyway
i tried acid waaaaaayyyyy back when i first started and really didn't like it, so i guess i'd like to know about cubase and cakewalk, other programs like that, or should i be perfectly fine with cool edit?
Old 12-05-2003
Newbie
also, the rap song has alot of cussing in it...so if someone wants me to censor it i could do that..
Old 12-05-2003
Jeyan's Avatar
Jeyan Jeyan is offline
Force of Nature
Jeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond repute
Re: Of all the computer programs to record with....
Originally posted by Rags
I use a apex 430 condenser mic, with a art tube mp preamp and... a top of the line sound blaster sound card.
Man, you definitely need a good soundcard, your music sounds good, but your soundcard is spoiling the whole thing, you could even hear clicks in teh middle of teh track. Get an audiophile 2496 they are way solid and better than any "TOP OF THE LINE SOUNDBLASTER"
Good Luck!
JJeyan
Old 12-05-2003
Newbie
plenty of people have the same card as i do and their music sounds crystal clear, i was under the impression it woulda been my pre-amp, like the settings were wrong or something...
the vocals come out sounding low, but in the cool edit prog, they're showing up like they're loud and that's where the clips are coming from
Old 12-06-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Yes - the SB card is definitely a weak point.... BUT......
...it also isn't completely about the gear -- you need recording SKILLS too.
Maybe you SHOULD be looking at your techniques,
Old 12-06-2003
manning1 manning1 is offline
Banned
Location: Canada.PLEASE NOTE>>I DONT WORK FOR NOR HAVE I EVER WORKED FOR ANY COMPANY WHOSE PRODUCTS I LIKE AND RECOMMEND.
manning1 is on a distinguished road
tips
if your recording with an sb card you must denoise and clean up
each track carefully. sample the sb noise in cool edit then apply a low ratio noise reduction to the track. do repeat passes at 5 to 10 percent. ive done recordings with sb cards in the past to show what can be done with them for friends entering the audio field. but the KEY is cleaning up the tracks.
frankly now that audiophile and mia and staudio are so cheap i
would consider a new sound card. also be aware fan noise from pc introduces noise particularly with sensitive condensers like the apex etc.
Old 12-06-2003
crosstudio's Avatar
crosstudio crosstudio is offline
Reggae + Go-Go = Regg'go
crosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond repute
if i were you my gear list would be:
1) sound card
2) mic pre
3) recording software (if you can identify something you need that you aren't getting with what you have).
ps. i use cakewalk sonar2. i'll be upgrading to sonar3 for christmas.
Old 12-06-2003
Newbie
i guess a new soundcard thread..
http://www.homerecording.com/bbs/sho...hreadid=106254
Old 12-06-2003
sonicpaint's Avatar
sonicpaint sonicpaint is offline
Dedicated Member
sonicpaint is on a distinguished road
It's not the program.
I agree with other comments made but it seems your looking for a program that will improve your recordings. I've used Cooledit for a couple of years before I made the jump to Pro Tools and I know CoolEdit is more than capable of recording and capturing your sound.
As BlueBear said it takes skills to produce great recordings. Maybe your getting frustrated at the level your at because your unable to achieve that sound you want at this point.
If you looking to improve on the "tools" your using, then I'd suggest listening to some of the other posts regarding your sound-card and pre(s) before turning your attention to the software.
Try not to be hard on yourself because as time goes on you learn more, improve your equipment and produce better recordings.
later,
sonicpaint
Old 12-06-2003
Newbie
i used to record with the worst soundcard probably ever made, and a radio shack mic for $4 bucks, that was probably back when i was 13 or 14, and then i got the sound blaster card and then the condenser mic just made everything sound so much better, but after 5 years I'm starting to want better
I'm toying with taking some type of music engineering program in school
Old 12-11-2003
Timmay Timmay is offline
Newbie
Timmay is on a distinguished road
I have acid 4.0 and was wondering what people think of it? As I was thinking of buying Pro Tools or Cakewalk Sonar.
Cheers
TIMMAY!
  #12
Old 12-11-2003
gaylord gaylord is offline
Newbie
gaylord is on a distinguished road
I use Logic Platinum (Emagic) and love it. It's got a steep learning curve but it's super powerful.
  #13
Old 12-11-2003
hummcat hummcat is offline
Newbie
hummcat is on a distinguished road
There are many programs avaialble on the market to suit your needs. You should ask yourself:
1) Is your task primarily tracking and mixing (then you may want to consider Pro Tools, Bias, etc.)
2) Is your task primarily composing (then you may want to consider Logic/Cubase/etc.
Pro Tools is still the industry standard in terms of recording. Their LE program (free!) is surprisingly powerful but their higher end stuff is still prohibitively expensive.
  #14
Old 12-11-2003
Havoc Havoc is offline
Force of Nature
Havoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond repute
Uh, no offence but changing programs isn't going to improve your mixing/mastering. Instead, you are going for another learning curve, making it even harder to progress.
  #15
Old 12-11-2003
sonicpaint's Avatar
Dedicated Member
I don't think he understands.
That's what I was saying too, along with others in this thread.
sonicpaint
