Old 12-03-2003
visa visa is offline
Senior Member
visa has a reputation beyond reputevisa has a reputation beyond reputevisa has a reputation beyond reputevisa has a reputation beyond reputevisa has a reputation beyond reputevisa has a reputation beyond reputevisa has a reputation beyond reputevisa has a reputation beyond reputevisa has a reputation beyond reputevisa has a reputation beyond reputevisa has a reputation beyond repute
what's a punch-in?
i have no idea what it is.
a detailed explaination?....anyone?
Old 12-04-2003
Atwork Atwork is offline
Dedicated Member
Atwork is on a distinguished road
It's where you erase an error and replace it with the part correctly played or sung. You can set up the recorder to start and finish at exactly the right points so you don't record over the bits you want to keep.
Old 12-04-2003
rguagenti rguagenti is offline
Senior Member
rguagenti has much to be proud ofrguagenti has much to be proud ofrguagenti has much to be proud ofrguagenti has much to be proud ofrguagenti has much to be proud ofrguagenti has much to be proud ofrguagenti has much to be proud ofrguagenti has much to be proud ofrguagenti has much to be proud ofrguagenti has much to be proud of
Adding to what Atwork said:
If you recorded a track and are happy with it except for a measure or two, you flubbed a chord change, you hit a bad note, whatever, instead of rerecording the whole track you can punch in at the bad points.
You can set up your recorder to "punch in" at a certain time or measure and "punch out" at a certain time or measure. After setting your punch in and out parameters, arm your track to record, then set yourself up about two or three measures in front of the punch in time. Press "record" and play along with the track. Play a little bit past the punch out time as well. The only part that will get rerecorded is the punch in and out times you have set. If you don't like that take, you can do it over and over until you get it right.
It's a very useful tool.
Hope this helps.
Old 12-04-2003
Senior Member
BTW you should punch in during the same recording session otherwise you will have to re-create the same conditions that existed at the time you originally recorded the track. Volume levels, etc.
Old 12-05-2003
jskillz89's Avatar
jskillz89 jskillz89 is offline
Dedicated Member
jskillz89 is on a distinguished road
couldnt have said it better my self
Old 12-05-2003
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
Also known as an overdub, if you're more familiar with that term.
Old 12-05-2003
lost studios's Avatar
lost studios lost studios is offline
Dedicated Member
lost studios is on a distinguished road
Re: what's a punch-in?
A punch-in is what I did everyday at 7:00AM for the start of my day doing slave labor in a factory before my studio started to support me. Personally, I prefer punching out much more.
Old 12-05-2003
Dedicated Member
You're right... you couldn't.
Old 12-08-2003
Han Han is offline
1K Silver Member
Han has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond repute
Sorry, but I have to disagree. A punch in/out is when you replace for example a couple of bad notes or bars on the same track.
The bass player missed a note and you re-record a small piece of the bass part.
An overdub is an extra track which is added to the already recorded tracks.
If you record a band at once, say drums, bass and guitar and you record a second guitar on an extra track, it's called an overdub.
Punching is only important when recording to tape. It's a special skill. A while ago I punched on a 2" machine, 21 tracks between two tom strokes in a drum brake. You got to have some luck too.
Old 12-08-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Thanks god for the undo button on digital recorders. I can't remember how many times I've accidentally punched over the wrong part or track.
I can't imagine the stress of doing it to tape anymore.
Old 12-09-2003
dachay2tnr's Avatar
One Hit Wonder
I have always heard the term used for both cases - recording an additional track into an existing project, AND for dubbing a correction to an existing track. "I need to overdub the guitar in the bridge."
That's not to say it wasn't being misused. Where's the official recording dictionary when you need it?
  #12
Old 12-09-2003
dachay2tnr's Avatar
One Hit Wonder
When all else fails, search the web:
Here's one definition I found:
OVERDUBBING, OVERDUBS - The process of replacing an excellent recording with progressively lower quality Overdubs attempts.
( Been there, done that.)
Here's another (which supports your definition) :
Overdub - the addition of new tracks layered over others. Overdub presumes that some tracks have already been recorded. You may do some overdubbing with your video projects, if you include both narrative tracks and music tracks.
Punch in - the re-recording of a particular segment. The engineer will "punch in" at a certain point and "punch out" again in order to improve the performance of a given section without changing or re-recording the rest of the performance.
So I'll stand corrected - I guess.
  #13
Old 12-09-2003
Audio Bum
Punching In is a subset of Overdubbing.
Anytime you add more tracks you are overdubbing. When you add a new piece in the middle of an existing track you are punching in the overdub.
