Go Back   Home Recording > User Forums by Brand > Cool Edit Pro / Adobe Audition Forum
Reply    Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 11-29-2003
formerlyfzfile's Avatar
formerlyfzfile formerlyfzfile is offline
Dedicated Member
formerlyfzfile is on a distinguished road
Question sending tracks outboard and then back in??
I am trying to send tracks from CEP 2 to my Tascam mixer and outboard gear via a Delta 44 and then return a 2 track mix via the Delta to two open tracks of CEP.
But the two open tracks record "in the box".
I cant seem to get the two open track to only record the outboard signal.
-mike
Old 11-29-2003
trigger's Avatar
trigger trigger is offline
Junior Member
trigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond reputetrigger has a reputation beyond repute
Sounds like you need to change the record source of your soundcard to 'Line In'. (not knowing your computer set up) Right click on your speaker in the taskbar...choose either 'mixer' or 'properties' and find the RECORD section and select LINE IN.
Right now, it sounds like you have either 'What you hear' or 'Wav' selected. (to record 'in the box' in CEPRO)
Hope this works.
Old 11-30-2003
Jeyan's Avatar
Jeyan Jeyan is offline
Force of Nature
Jeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond repute
Trigger, he is using a Delta 44 sound card and not soundblaster.
JJeyan
Old 11-30-2003
Dedicated Member
Yeah..its a Delta....
but I get the jist of what Trigger's saying and I have routed the 4 tracks in CEP out to each of the 4 outs of the Delta....with the channels hard panned left/right left/right.
The two open tracks are set to recieve input from the 1/2 inputs of the Delta (hard panned l/r).......but they are recieving inputs from within CEP and even if I turn my outboard mixer off they are recording a mix of the 4 playing tracks.
I need to make the inputs and outputs decrete.
Thanks though.
Any other thoughts???
-mike
Old 12-01-2003
Chrisjob Chrisjob is offline
prolegomena
Chrisjob is on a distinguished road
Make sure you're delta patchbay/router is selected to the appropriate outputs.
Old 12-01-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Check your Delta driver control panel. A lot of times they default outputs 1/2 to 'Monitor Mix' which always gives you everything.
